TENDRIL Posted February 10, 2015 Report Share Posted February 10, 2015 Yep it worked too!! Hole was about the size o a nickel Quote Link to comment
skyblue Posted February 16, 2015 Author Report Share Posted February 16, 2015 Did some more bondo/paint removal. Used a heat gun this time. And it worked great. Got all bondo and paint off rear hatch piece. I knew it was toast and I'm replacing it anyways, but I wanted to see how bad really it was under all that bondo. 2 Quote Link to comment
Draker Posted February 16, 2015 Report Share Posted February 16, 2015 wow.. scary stuff. 1 Quote Link to comment
Busta Nut Posted February 16, 2015 Report Share Posted February 16, 2015 Just leave it like that and clear coat it..... 5 Quote Link to comment
westonstonehocker Posted February 17, 2015 Report Share Posted February 17, 2015 you should get paint stripper for the whole car, maybe even that aircraft paint stripper it'll eat through fiberglass too. not sure about bondo though. sry bout all that rust btw Quote Link to comment
2050-Z Posted February 17, 2015 Report Share Posted February 17, 2015 Wow. That's bad. Why don't you grab a CA shell without 90% of that rust and bondo? Quote Link to comment
skyblue Posted February 18, 2015 Author Report Share Posted February 18, 2015 you should get paint stripper for the whole car, maybe even that aircraft paint stripper it'll eat through fiberglass too. not sure about bondo though. sry bout all that rust btw Actually I did start out using paint stripper. But once I got to the bondo layer it was taking too much stripped to remove. So I researched how to remove bondo and heat was one option that I decided to try. Thanks. Lol Wow. That's bad. Why don't you grab a CA shell without 90% of that rust and bondo? Well that would be too easy. Lol. I thought about that. But in the end I realized this would be a good car to practice my welding/body work/patching skills on. Plus I'd be taking a pretty big loss. So I will make the best of what I got. 1 Quote Link to comment
2050-Z Posted February 18, 2015 Report Share Posted February 18, 2015 Plus I'd be taking a pretty big loss. http://en.wikipedia.org/wiki/Sunk_costs Quote Link to comment
skyblue Posted February 19, 2015 Author Report Share Posted February 19, 2015 Yes, well with classic cars you can sometimes break even. And in some wild cases even make a profit. Lol 1 Quote Link to comment
Ryan Family 510 Posted February 20, 2015 Report Share Posted February 20, 2015 I agree you should practice welding then just clear it!!! 1 Quote Link to comment
skyblue Posted March 3, 2015 Author Report Share Posted March 3, 2015 The GF has been out of town so no car updates. But, my beads are getting better. 4 Quote Link to comment
skyblue Posted March 10, 2015 Author Report Share Posted March 10, 2015 Tonight's class was good. Finally got some decent butt welds done. Don't mind that middle one. :) Killing the flat beads 3 Quote Link to comment
Laecaon Posted March 10, 2015 Report Share Posted March 10, 2015 I usually use a propane torch on Bondo. Stinks, but it comes off fairly easily. 1 Quote Link to comment
2050-Z Posted March 10, 2015 Report Share Posted March 10, 2015 EDIT: wrong topic Quote Link to comment
skyblue Posted March 10, 2015 Author Report Share Posted March 10, 2015 I usually use a propane torch on Bondo. Stinks, but it comes off fairly easily. I thought about that. But I read bondo smoke is pretty toxic. Quote Link to comment
skyblue Posted April 7, 2015 Author Report Share Posted April 7, 2015 I just can't say no to that face. Been busy with stuff, but took an hour and peeled off more of the bondo. 4 Quote Link to comment
EastBay521 Posted April 7, 2015 Report Share Posted April 7, 2015 Tonight's class was good. Finally got some decent butt welds done. Don't mind that middle one. :) Killing the flat beads i wana learn to weld now 4 Quote Link to comment
TENDRIL Posted April 8, 2015 Report Share Posted April 8, 2015 try pushing back into your puddle a bit more, you will get more uniform sides ------------------------------------------------------------------------------------------------------------------------------------------------------------ Weave Patterns Circular Pattern: Used for flat position welds on butt, tee, outside corner joints and buildup or surfacing applications. "C", Square Pattern: Good for most flat welds, but can be used for vertical positions. "J" Pattern: Works well on flat lap joints, and horizontal butt and lap welds. "T" Pattern: Works well with fillet welds in the vertical and overhead position. Straight Step Pattern: Used for stringer beads, root pass welds, and multiple pass welds in all positions. Figure 8, Zigzag: Used as cover passes in the flat and vertical positions. 5 Quote Link to comment
skyblue Posted April 8, 2015 Author Report Share Posted April 8, 2015 that square is crazy. are these for oxy welding or? Quote Link to comment
skyblue Posted April 8, 2015 Author Report Share Posted April 8, 2015 and i've gotten a little better. don't mind the bottom weld also did my first fillet welds 5 Quote Link to comment
TENDRIL Posted April 8, 2015 Report Share Posted April 8, 2015 looking damn good!!! 3 Quote Link to comment
EastBay521 Posted April 23, 2015 Report Share Posted April 23, 2015 I have to thank you mike for giving me the inspiration to weld. i took the welder out at school today and just went for it im assuming it could have been worse for my first attempt... keep comin with the updates youre an inspriation to us all 6 Quote Link to comment
skyblue Posted April 23, 2015 Author Report Share Posted April 23, 2015 Dood nice! I'm glad I could inspire. Looks like you're off I a great start. Keep practicing and you'll be a pro in no time. 3 Quote Link to comment
skyblue Posted April 23, 2015 Author Report Share Posted April 23, 2015 Finally got on the mig and been practicing. In Z news, it is getting relocated soon. Will post pics when it moves. 5 Quote Link to comment
FirstDime Posted April 23, 2015 Report Share Posted April 23, 2015 i dont know how to weld but those look pretty nice and neat man, keep it up :thumbup: so we finally get to meet pepper soon :w00t: 2 Quote Link to comment
