ohmrchristopher Posted September 30, 2014 Report Posted September 30, 2014 I know this is more classified material but I figured I ask right from the source. I need a set of stock 620 short box springs and a rear axel. Truck is '73 1.6L 4spd. But if it's easier to ship I technically need a new diff, mines been welded. I'm in kelowna, bc Canada. Quote
JNHEscher Posted October 5, 2014 Report Posted October 5, 2014 I have the springs and the diff. I kept axle housing though. I do have a 720 housing with axles. They're a bit wider but could work depending on what wheels you use. Quote
datzenmike Posted October 5, 2014 Report Posted October 5, 2014 All models of 620 use the same spring length.The 520/521 and 720 springs are the same length and width and will fit the early 620. They do come in a variety of spring rates thicknesses, and number of leaves. If you are looking at lowering, the 720 4x4 springs are flatter and stiffer. Quote
ohmrchristopher Posted October 5, 2014 Author Report Posted October 5, 2014 Bought a set off some tight ass old timer who thinks his shit don't stink and a grille is worth $100. 620 short box springs that he "re arced" and a axel, flange to flange but he took all the brakes off (cheap cunt) cost me $320. I'll post photos of the spring packs tomorrow including mine. Quote
