DISLEXICDIME 489 Posted September 20, 2014 Report Share Posted September 20, 2014 Or have a sr20det Quote Link to post
Stoffregen Motorsports 5,569 Posted September 20, 2014 Author Report Share Posted September 20, 2014 I've seen 510's with TOO MUCH horsepower. At a track day at Thunderhill I was pitted next to a guy with a turbo SR20, the turbo was so big it poked out of the hood. He said he had about 450 HP and it was so much he said it wasn't even fun. He would just smoke the tires off when he rolled on the gas, even at speed. To get traction with big HP you need to run such a big tire that the car is almost as wide as it is long. 1 Quote Link to post
DISLEXICDIME 489 Posted September 20, 2014 Report Share Posted September 20, 2014 Yup . But a t25 or 28 on a Sr is fun Quote Link to post
DISLEXICDIME 489 Posted September 20, 2014 Report Share Posted September 20, 2014 I would like to try peradimes set up it looks fun 1 Quote Link to post
paradime 7,741 Posted September 21, 2014 Report Share Posted September 21, 2014 I've seen 510's with TOO MUCH horsepower. At a track day at Thunderhill I was pitted next to a guy with a turbo SR20, the turbo was so big it poked out of the hood. He said he had about 450 HP and it was so much he said it wasn't even fun. He would just smoke the tires off when he rolled on the gas, even at speed. To get traction with big HP you need to run such a big tire that the car is almost as wide as it is long. Although I've heard it said that anything over 250 hp in a 510 is overkill, I don't believe that is true at all. It's a matter of how that power is delivered. With most modern stand alone engine management systems, you have the ability to control how much power is sent in each gear, at what speed, rpm and so on. You can program the ECU to trim power to say 50% in 1st gear, 65% in 2nd, 80% in 3rd, and full in 4th and 5th. You can also control boost in real time by referencing multiple data points to adjust boost on the fly. Kind of a poor man's traction control. Working with a good dyno tuner there's no reason you couldn't tame 450hp so you could use it where and when you can use it. The drawback of a massive turbo is it takes much more exhaust flow to spool up requiring higher rpms to stay in positive boost power range. Then if you don't carefully control the boost curve, it's like riding a rocket with an on/off switch. That might work on a drag strip, but at an auto-X course. No fun! If he is spinning wheels at speed that sounds like his rear is lifting suggesting poor airflow management. At that speed a serious air dam and side skirts are not just for show. The more air you can divert to the top of the car the less lift you get at speed. Although I've seen (non SCCA vintage/production) 510s with a small rear spoiler. I doubt it's creating any down force, but all you really need is to disrupt the air flow to break up the pressure build up on that blunt ass end. . Does anyone know if there have been any land speed testing done with the 510? 2 Quote Link to post
Duke 342 Posted September 21, 2014 Report Share Posted September 21, 2014 135, and now 140mph hmmm! Those are some serious in a 510 numbers that to me need verification with gps and a picture are needed. I mean a 510 isn't exactly aerodynamic and more like pushing a Billboard through the air. I'm not saying you didn't, I'm just having a hard time swallowing the cool aid. I've done 118 in my 510 with a S14 SR20DE with 180hp and it had more but I don't think it had 130-140mph more. I have a lot of suspension mods and it was pretty damn smooth at speed even with halfshafts but then it isn't slammed to the ground. Just Saying.. If I had a third hand to hold the camera, I could take a picture for you, but at high speeds, I prefer to hold onto the wheel with my the two hands I have. Using one of the many aero calculators available online, the top speed that I posted should theoretically take about 180hp to achieve (which I believe is right around what my KA is making). With CV's in the rear, ~6* castor in the front, and a good amount of rear toe in, the ride is surprising smooth and stable at high speed. Honestly though, 510's are way more fun between 40 and 80 mph than at 100+. 3 Quote Link to post
q-tip 11,641 Posted September 22, 2014 Report Share Posted September 22, 2014 Honestly though, 510's are way more fun between 40 and 80 mph than at 100+. Could not be more true 2 Quote Link to post
Nuclear Water Boy 35 Posted September 23, 2014 Report Share Posted September 23, 2014 Duke no camera mount? B) I bet your 510 is silky smooth (for a 510) with those mods. If i'm wanting to go 130+ I'd be doing it in something that can easily achieve that and more. To bad my buddies NHRA Jet car doesn't have a passenger seat, that 305mph he did looks like fun. Lou "Have Depends will ride" Quote Link to post
datson4life 2,320 Posted September 23, 2014 Report Share Posted September 23, 2014 Not in a 510 but in my ka 521 , speedo wasnt hooked up, but whatever 6300 rpm is in 5th gear Quote Link to post
q-tip 11,641 Posted September 23, 2014 Report Share Posted September 23, 2014 What's your rear gear? Quote Link to post
67_1600 552 Posted September 23, 2014 Report Share Posted September 23, 2014 Not in a 510 but in my ka 521 , speedo wasnt hooked up, but whatever 6300 rpm is in 5th gear With a stock rear end with 4.375 gears and then combine that with 205/50/15 tires (not sure what you actually have) and a 5th gear of .759 would come out to 133 MPH @ 6300 RPM. Would need to know whether you have the stock rear end or not and your tire size to get a closer calculation. 1 Quote Link to post
paradime 7,741 Posted September 23, 2014 Report Share Posted September 23, 2014 Duke no camera mount? B) Is this what they mean by "The show me State"? Wait a minute, you live in NH. Quote Link to post
q-tip 11,641 Posted September 23, 2014 Report Share Posted September 23, 2014 With a stock rear end with 4.375 gears and then combine that with 205/50/15 tires (not sure what you actually have) and a 5th gear of .759 would come out to 133 MPH @ 6300 RPM. Would need to know whether you have the stock rear end or not and your tire size to get a closer calculation. I was just going to answer with a hell of a lot fast than you should be going in a 521, but 130 sounds about right Quote Link to post
paradime 7,741 Posted September 23, 2014 Report Share Posted September 23, 2014 Here's the real question though; Is a 521 more aerodynamic than a 510? All depends on the quality of the butter you use. Quote Link to post
datson4life 2,320 Posted September 23, 2014 Report Share Posted September 23, 2014 Yes stock rear, more like 120 maybe, 15 inch wheels with 195-50 tires, the gear ratios and smaller wheels and tires made it rip thru the gears pretty quick Quote Link to post
datson4life 2,320 Posted September 23, 2014 Report Share Posted September 23, 2014 I was just going to answer with a hell of a lot fast than you should be going in a 521, but 130 sounds about right I let off cause it wasnt pleasant, thats the one and only time i pushed it like that, it was a very nice abandoned airport :-) :-D ;-) Seriously tho, away from society, got some vids, but cant upload, and maybe shouldn't lol Quote Link to post
datzenmike 39,204 Posted September 24, 2014 Report Share Posted September 24, 2014 I get 128.062MPH. I think the 521 would be more stable than the 510 at speed. Quote Link to post
q-tip 11,641 Posted September 24, 2014 Report Share Posted September 24, 2014 I think the 521 would be more stable than the 510 at speed. You might be right, but neither is actually stable at that speed unless heavily modified Quote Link to post
datzenmike 39,204 Posted September 24, 2014 Report Share Posted September 24, 2014 I think the 521 would be more stable than the 510 at speed. As in, if I had to be in one of them, I would want the 521, is all. And rubber pants. 1 Quote Link to post
Stoffregen Motorsports 5,569 Posted September 24, 2014 Author Report Share Posted September 24, 2014 The strut front end of the 510 would likely be more stable than the poor geometry of a 50 year old upper/lower control arm and kingpin setup, but the solid axle rear woulddefinitely be more stable. And the aerodynamics of the truck bed may actually help. Not that I'd want to do 130 in a 521, but never say never. Quote Link to post
67_1600 552 Posted September 24, 2014 Report Share Posted September 24, 2014 I get 128.062MPH. I think the 521 would be more stable than the 510 at speed. Check your math - with the slightly smaller tires I get 128.061785126. 1 Quote Link to post
datzenmike 39,204 Posted September 24, 2014 Report Share Posted September 24, 2014 The thing I was thinking of was the much stiffer suspension.... and it's heavier. Quote Link to post
datzenmike 39,204 Posted September 24, 2014 Report Share Posted September 24, 2014 Check your math - with the slightly smaller tires I get 128.061785126. (tire stretch from centrifugal forces) ;) 1 Quote Link to post
datson4life 2,320 Posted September 24, 2014 Report Share Posted September 24, 2014 How do u guys do the math? The transmission was off a ka truck aswell, someone mentioned the gear ratios are different than the 240sx transmissions Quote Link to post
q-tip 11,641 Posted September 24, 2014 Report Share Posted September 24, 2014 As in, if I had to be in one of them, I would want the 521, is all. And rubber pants. I knew what you meant Mike, I was just saying that neither of them are made to do those speeds. Quote Link to post
