allen dodson Posted September 16, 2008 Report Share Posted September 16, 2008 Hi. I have tow good 4 speeds here. A 240z and a 260z 4 speed that i would like to use in place of my stock 4 speed in my 521 pickup. I think the Z car 4 speed will have closer gear ratios than the stock 521 4 speed. My question is will it fit? I think the Z trannys a little longer so a ne drive shaft will have to be found. But will the Z bolt up to the L16 block? Quote Link to comment
79datsun620 Posted September 17, 2008 Report Share Posted September 17, 2008 i know that it will work with L18 and if im not mistaken L16 & L18 block are the same except for the bore.should bolt right up:D Quote Link to comment
Bleach Posted September 17, 2008 Report Share Posted September 17, 2008 you are correct. It will bolt up and it will be too long. if you take the time to do a custom rear tranny mount and have the driveshaft shortened then you have options for long tail transmissions. (z car 5-speed) in the future. Those are much easier to find than other Datsun transmissions. Quote Link to comment
79datsun620 Posted September 17, 2008 Report Share Posted September 17, 2008 yeah i have a 280z 5 speed in my 620:D Quote Link to comment
Bleach Posted September 17, 2008 Report Share Posted September 17, 2008 and lucky for you the late 620 like you have is the same length. 280Z transmissions bolt right in. poor 521 owners :D Quote Link to comment
datzenmike Posted September 18, 2008 Report Share Posted September 18, 2008 Hi. I have tow good 4 speeds here. A 240z and a 260z 4 speed that i would like to use in place of my stock 4 speed in my 521 pickup. I think the Z car 4 speed will have closer gear ratios than the stock 521 4 speed. My question is will it fit? I think the Z trannys a little longer so a ne drive shaft will have to be found. But will the Z bolt up to the L16 block? Rather than shortening your drive shaft, get the front drive shaft from a '74-'79 620 that already has the longer 4 or 5spd in it. You will still have to fab a rear tranny mount for the 521. Quote Link to comment
