Marsh510 Posted September 11, 2014 Report Share Posted September 11, 2014 I was thinking about some chicken tenders at this time. Well, I just recently picked up a 1975 710 wagon from a friend for a good price. Here's a picture for now. Would like to go lowlow on this goon, any suggestions on suspension? Just picked up from 3' lowering blocks, and was thinking about 280zx front suspension. Quote Link to comment
Greased monkey Posted September 12, 2014 Report Share Posted September 12, 2014 Nice! I can't wait for mine to arrive at the port and make it's way to the garage :) I will be watching this car come to life I hope Quote Link to comment
datzenmike Posted September 12, 2014 Report Share Posted September 12, 2014 Just the 280zx struts. Remove the spring and lower perch. Trim your 710 spting and use your perch on the zx and split collars to hold and adjust the height with. Cost about $25. Three inch blocks ok but add a flat extra leaf on the back to reduce and stiffen the rear to prevent bottoming. When you get the zx struts get the 15/16" master to go with it. I did on mine and the peddle feel is great. New rotors and pads. The 710 top hat is also off set if you look. This will help with setting camber. Quote Link to comment
