cgovia Posted September 16, 2008 Report Share Posted September 16, 2008 Just got my 620 and I was driving to work this AM and it died like there was no fuel so I waited about 3 min and cranked it for about 3 times and it started then started to drive and about 50 yards the same thing (SICK)Im did that for about three times same thing. It does it even when it idles its got a 32/36 on it 1800 motor vacume lines are not plugged so can anyone shed some light on this Thanks :mad::mad: Quote Link to comment
DISLEXICDIME Posted September 16, 2008 Report Share Posted September 16, 2008 i bet the fuel pump or fuel filter is bad Quote Link to comment
yello620 Posted September 16, 2008 Report Share Posted September 16, 2008 Also remember to check the fuel filter that is inside the weber carb inlet. Jason Quote Link to comment
slodat Posted September 16, 2008 Report Share Posted September 16, 2008 My vote is fuel pump. Happened on two dattos. A good Japanese fuel pump on ebay Quote Link to comment
hang_510 Posted September 16, 2008 Report Share Posted September 16, 2008 check the cheap / easy fix first Quote Link to comment
cgovia Posted September 16, 2008 Author Report Share Posted September 16, 2008 replaced filter ran good longer than before but still stalling new filter has a lot of crap in it also will try to get a line and connect it to the in comming side of the filter and to a gas can and see if it gets better Quote Link to comment
HRH Posted September 16, 2008 Report Share Posted September 16, 2008 Watch out for rust in the tank. I had to run a sediment bowl on one of my previous wagons. You can get those at any farm and feed store. NAPA has them too. Quote Link to comment
cgovia Posted September 16, 2008 Author Report Share Posted September 16, 2008 found rust in tank where do you put the settlement bowl at ? Quote Link to comment
slodat Posted September 16, 2008 Report Share Posted September 16, 2008 Drop the fuel tank and have it boiled out at a radiator shop. Then flush out/blow out the fuel line. Replace the filter at the least. You may want to replace the pump (that $10 one I posted above is a great deal). I'd also check the inlet filter screen on the carb's fuel inlet. My .02 Quote Link to comment
cgovia Posted September 16, 2008 Author Report Share Posted September 16, 2008 sounds like a plan ,looked for pump but the ebay store has none ,thanks Quote Link to comment
