Airplane Porn (and the occasional helicopter)
  • Replies 9.8k
1 hour ago, wayno said:
I read or heard somewhere that the F4U Corsair was hard to land on the aircraft carriers unless they did a "U" shaped approach so they could see where to land as the fuselage was in the way of what was right in front of them.
That's correct, the British figured out that by coming in on a curve helped the pilots keep the landing officer in eyesight and they could see his landing instructions.
By solving that problem, and technical ones, the Corsair was fit for Carrier Duty in 1944
There are two versions of the F4U Corsair.  The different versions are easily identified by a three or a four blade propeller.  Less noticeable is the four blade propeller versions had a longer nose, to accommodate a 28 cylinder, four row radial engine.  The three blade versions had a two row 14 cylinder radial engine.
The large propeller diameter got close to the runway on takeoff, and landing, so the wings were bent up at the landing gear location to raise the fuselage and engine of the plane farther from the ground, or carrier deck.
