hobospyder Posted December 30, 2016 Author Report Share Posted December 30, 2016 you can have the single post if you want to come and get it Link to comment
ErickwithnoK Posted December 31, 2016 Report Share Posted December 31, 2016 Jealous of your shop space. Is it heated or is the "new" stove the first time you've had a warm shop to work in? 1 Link to comment
Draker Posted December 31, 2016 Report Share Posted December 31, 2016 I'm pretty sure I'd have to dig a big pit in my garage to fit the one post. If it works, I'd say you keep it.. and get a two post. :w00t: Link to comment
hobospyder Posted December 31, 2016 Author Report Share Posted December 31, 2016 Jealous of your shop space. Is it heated or is the "new" stove the first time you've had a warm shop to work in? wasn't heated until the stove got there and with the way it's set up right now still isn't properly heated, does help some though I'm pretty sure I'd have to dig a big pit in my garage to fit the one post. If it works, I'd say you keep it.. and get a two post. :w00t: that's the plan. probably eventually cap off the one post since it's in my parking space Link to comment
hobospyder Posted December 31, 2016 Author Report Share Posted December 31, 2016 got the engine out of little miss and dropped into ducky today. fucking ted came up to drop off parts for ducky and assisted in the pulling and dropping of the motor. nothing is connected but it's in the hole and against fucking teds advice i dropped the short tail tranny into the 77. cross member from the 73 worked out just fine though probably got flipped in the process since i don't know which way was forward on it 1 Link to comment
hobospyder Posted December 31, 2016 Author Report Share Posted December 31, 2016 also the words fucking ted were actually spoken today. to him 2 Link to comment
hobospyder Posted January 8, 2017 Author Report Share Posted January 8, 2017 got down to the shop for a couple hours before getting hungry as i haven't eaten yet today and cold because, well, it's cold out. just hooking up what i can, battery side is mostly done except the earth for the alternator and the battery, gonna need help with the manifold side as the wire loom is an absolute mess and i'm lost... radiator and fan shroud is in, lower rad hose connected, attempted to do the upper hose but well.... didn't have an upper to begin with and the upper from little miss won't work so attempted modifying the old lower from the truck which... yeah didn't work. walked up to the house after that with the chunk of hose, after checking toolbox to see if he has an upper hose.... nope, no radiator or anything.... may or may not get back down there today Link to comment
hobospyder Posted January 8, 2017 Author Report Share Posted January 8, 2017 Numbers for later use. 225 50 17, 215 55 16. 1 Link to comment
Draker Posted January 8, 2017 Report Share Posted January 8, 2017 They are cheap enough.. but also, you could force that and make it work. Link to comment
hobospyder Posted January 9, 2017 Author Report Share Posted January 9, 2017 They are cheap enough.. but also, you could force that and make it work. it kinks on the forward bend. will probably go get one during the week Link to comment
hobospyder Posted January 9, 2017 Author Report Share Posted January 9, 2017 went back out to the shop. got the transmission cross member fully installed so got the jack out from under the truck. then started looking at the brakes and rear axle..... need to get the blue truck moved back down to the shop instead of the garage it's in, just gonna take the rear axle out from that one and use it on the longbed instead of just yanking one of the two inner axles out. had already pulled the wheels off so decided to throw a different set of wheels onto the truck before moving it around in the shop. hence the numbers from earlier, you should've been able to tell they were for tires. probably gonna keep these on there. been thinking about it. sorry hippie 2 Link to comment
hobospyder Posted January 9, 2017 Author Report Share Posted January 9, 2017 altitude adjustment for later 1 Link to comment
hobospyder Posted January 13, 2017 Author Report Share Posted January 13, 2017 tires will be 22545 17. when i get that far, if i keep those rims on there Link to comment
hobospyder Posted January 23, 2017 Author Report Share Posted January 23, 2017 ducky is now running videos will be posted but here's your warning that's all the exhaust that's on there right now after killing it i played around and debated killing out the bottle that gas was in but didn't want to empty out the fuel in the system random pictures enjoy, thanks for looking in also, thanks redeye for the haynes, it helped out a little. side note, had to swap out the ballast resistor from little miss, the one that was in ducky started crackling and smoking after i tried cranking before i switched to using the bump starter 3 Link to comment
]2eDeYe Posted January 23, 2017 Report Share Posted January 23, 2017 No problem, glad it was of some help. Sounds good, needs a muffler :thumbup: :lol: 1 Link to comment
hobospyder Posted January 23, 2017 Author Report Share Posted January 23, 2017 No problem, glad it was of some help. Sounds good, needs a muffler :thumbup: :lol: wanna build it? Link to comment
]2eDeYe Posted January 23, 2017 Report Share Posted January 23, 2017 Maybe.... Do you plan to run a new exhaust or cobble something together? Link to comment
hobospyder Posted January 23, 2017 Author Report Share Posted January 23, 2017 There is nothing left of exhaust on that long bed. And it only has to hold up for a couple years hopefully so I was debating buying flex pipe and hooking up the old exhaust Link to comment
]2eDeYe Posted January 23, 2017 Report Share Posted January 23, 2017 Flex pipe and 'hold up' aren't usually used in the same paragraph. :lol: 2 Link to comment
hobospyder Posted January 26, 2017 Author Report Share Posted January 26, 2017 :rofl: I only have to make it through Vin inspection. After that it's whatever 1 Link to comment
hobospyder Posted February 10, 2017 Author Report Share Posted February 10, 2017 so picked up one of these to replace my... ignition switch thing? http://community.ratsun.net/topic/29794-datsundaves-new-startstop-button-ignition-system/page-1 have a link, no picture, boxes are still in my car. quality looks top notch and dasundave is a standup guy, had me in his house and explained everything to me before bsing. and here's a skib how to on installing the button http://community.ratsun.net/topic/30513-dz-start-module-install/ lots of them out there, but i have one now. looking forward to installing 2 Link to comment
FrankRizzo Posted February 15, 2017 Report Share Posted February 15, 2017 so picked up one of these to replace my... ignition switch thing? http://community.ratsun.net/topic/29794-datsundaves-new-startstop-button-ignition-system/page-1 have a link, no picture, boxes are still in my car. quality looks top notch and dasundave is a standup guy, had me in his house and explained everything to me before bsing. and here's a skib how to on installing the button http://community.ratsun.net/topic/30513-dz-start-module-install/ lots of them out there, but i have one now. looking forward to installing I thought DD stoped making/selling those kits a while ago?? what/how/where did ya git it??? inquiring minds wanna know. I bought a 3rd party kit and am going to try and install this weekend... . Link to comment
hobospyder Posted February 15, 2017 Author Report Share Posted February 15, 2017 I thought DD stoped making/selling those kits a while ago?? what/how/where did ya git it??? inquiring minds wanna know. I bought a 3rd party kit and am going to try and install this weekend... . click the first link in that quote of yours and go to the end. He's doing a limited run from what I understand. And I'm hoping to get two more 1 Link to comment
FrankRizzo Posted February 15, 2017 Report Share Posted February 15, 2017 Yeah. I just found that. Scrolled to the end and saw it... :mad: im already all in on another kit... Link to comment
hobospyder Posted February 15, 2017 Author Report Share Posted February 15, 2017 I might buy 3 just in case you can't get yours to work Link to comment
