new guy needs help, hot front brake rotors....
  • Replies 29
Sounds like the pressure is not fully released when you let off the brake. This can happen when the master can't return fully to it's rest position.
Push down on the brake peddle with your thumb. There should be about 1/16" of free travel before there is stronger resistance. Does it have this play?
.....I did the brake pedal test, and there is a little play before it gets stiff, but not much, maybe half of a inch... that was one of the things my shop mentioned was how stiff the brake pedal was.. but they said calipers were working fine....
If you did this then 1/2" is way pleanty. Usually a few 16ths
hey mike, I got the master cylinder off, and screwed in the output rod on the brake booster.. major reduction in heat on the rotors...good news.....what does the check valve do exactly that runs from the manifold to  the brake booster..should I replace it or not worry about it....   ps  that  74 710 you have.  is that  a pickup...
