bagged_datsun Posted September 16, 2008 Report Share Posted September 16, 2008 as the headline says i have a hitachi carb for sale $30 does not include the manifold just the carb Link to comment
bagged_datsun Posted September 16, 2008 Author Report Share Posted September 16, 2008 also forgot that this came from a running truck Link to comment
datsunaholic Posted September 16, 2008 Report Share Posted September 16, 2008 Might want to note that it is a Z20S carb, not an L-series carb even though it's pictured on an L-series engine (note the post-type air cleaner bolt, lack of a neck to clamp the L-series air cleaner to, and the fact that it says "Z20S" on the choke heater). Link to comment
Bugeye Posted September 16, 2008 Report Share Posted September 16, 2008 will it work on a L series? Link to comment
bagged_datsun Posted September 16, 2008 Author Report Share Posted September 16, 2008 will it work on a L series? yup, was on an L when i got it Link to comment
datsunaholic Posted September 16, 2008 Report Share Posted September 16, 2008 Sort of, but the air cleaner won't fit (so it wouldn't pass smog visual checks). I used one on my '74 for a while until I put a weber on it, but used an air cleaner off a 720. Problem with that was the snorkel ended up on top of the master cyl (really long snorkel meant for running across and bolting to the NAPS-Z valve cover) Link to comment
bagged_datsun Posted September 17, 2008 Author Report Share Posted September 17, 2008 25 anyone? Link to comment
datzenmike Posted September 17, 2008 Report Share Posted September 17, 2008 Might want to note that it is a Z20S carb, not an L-series carb even though it's pictured on an L-series engine (note the post-type air cleaner bolt, lack of a neck to clamp the L-series air cleaner to, and the fact that it says "Z20S" on the choke heater). Good eye Doug. I tried to read it but only works when you know the answer. Didn't see the post. Link to comment
bagged_datsun Posted September 24, 2008 Author Report Share Posted September 24, 2008 does anyone have a center consul that hold's a radio that they would like to trade for the carb? Link to comment
