Mydime Posted September 16, 2008 Report Share Posted September 16, 2008 Hello I have a fuel injection conversion for the datsun L-20B I beleive that I have everything you will need minus the fuel pump, and EGR block off plate. This will bolt on to your Datsun L20B block converting your old carb set up to a fuel injected motor. Installation of pistons are required to maintain the proper compression ratio. $650 Included: 2- EFI Cylinder Heads. 2- Exhaust Manifolds. One is a stainless tubular header, the other is a stock cast iron. 1- Timing Cover 1- Valve Cover 1- Intake Manifold with sensors, fuel rail, injectors, injector resistors. 2- Ignition Coils 1- Distributor 1- Wire harness with all sensors,ECU, and factory mechanics wiring diagram with conversion cheat sheet. 4- Brand New In Box Cast 87mm flat top pistons with rings. I do accept paypal. I will ship at the buyers cost but be warned this would be a two box shipment and both boxes would still be both quite heavy so please be sure that you want to pay shipping for something this large. Thanks for taking the time to look. Link to comment
ppeters914 Posted September 16, 2008 Report Share Posted September 16, 2008 Crap. Trade for comic books? :rolleyes: Link to comment
Mydime Posted September 16, 2008 Author Report Share Posted September 16, 2008 hmmm...lets see....the edition of the introduction of batmans arch nemesis lex luther....sounds great but I like the green backs...LoL:D Link to comment
Mydime Posted September 18, 2008 Author Report Share Posted September 18, 2008 hmmm...lets see....the edition of the introduction of batmans arch nemesis lex luther....sounds great but I like the green backs...LoL:D Wow...... batman...lex luther.....what was I thinking....lets try super man Link to comment
ppeters914 Posted September 19, 2008 Report Share Posted September 19, 2008 any pics? Of what....the EFI or the comics? Link to comment
datzenmike Posted September 19, 2008 Report Share Posted September 19, 2008 I remember buying an original Fantastic 4, JLA, Metal Men, Magnus; Robot Fighter and Spider Man when I was a kid. What would they be worth now I wonder? Link to comment
Mydime Posted September 19, 2008 Author Report Share Posted September 19, 2008 here they are on the realm, http://the510realm.com/phpBB3/viewtopic.php?f=10&t=10195 Link to comment
pl521sss Posted September 19, 2008 Report Share Posted September 19, 2008 that's not a L20B It's a NapZ motor EFI setup Not a bolt on deal for L20B motor Link to comment
Mydime Posted September 19, 2008 Author Report Share Posted September 19, 2008 Neer said "it" was L20, yes this is the z head, I said it is a l20B efi conversion, never said "it" was bolt on either, I did say the 87mm pistons are required in the first post to keep up the compression to compensate for the z heads larger CC, meaning you have to bore your block 2mm, so if you are wanting to convert your datsun to efi you would want to use the L20 block since it is less prone to cracking, Link to comment
pl521sss Posted September 19, 2008 Report Share Posted September 19, 2008 Neer said "it" was L20, yes this is the z head, I said it is a l20B efi conversion, never said "it" was bolt on either, I did say the 87mm pistons are required in the first post to keep up the compression to compensate for the z heads larger CC, meaning you have to bore your block 2mm, so if you are wanting to convert your datsun to efi you would want to use the L20 block since it is less prone to cracking, Ok You stated "This will bolt on to your Datsun L20B block" just a little bit misleading without all the info there or picture. No troubles here bro Hope someone gets it and put to good use. Link to comment
Mydime Posted September 19, 2008 Author Report Share Posted September 19, 2008 no problem, I didn't spell it out so I see how there could be a misunderstanding. Link to comment
slodat Posted September 20, 2008 Report Share Posted September 20, 2008 When people see L20b EFI conversion, they will naturally automatically think it is the L18E manifold... Just a FYI.. Link to comment
