sdsurf Posted September 16, 2008 Report Share Posted September 16, 2008 I am going to mount my carb to the manifold and was wondering if I should use some blue rtv silicone... I ave "used" gaskets I am going to try use temporarily... Quote Link to comment
Pacific coast Datsun Posted September 16, 2008 Report Share Posted September 16, 2008 I used black silicone on my old Weber to seal up a vaccum leak & it worked great. Id sandwich a thin layer on both sides of the gasket before bolting it down. Quote Link to comment
yello620 Posted September 16, 2008 Report Share Posted September 16, 2008 The RTV/Permatex can be used as a very temporary band-aid. The gasoline will soften the rtv and produce a vaccumn leak that is worse than before. Not a recommened practice at all. Might get you by until your new gaskets get ordered the next day, but why. Just get yourself a roll of the make-your-own gasket material and make some. They will be far superior to the RTV band-aid. Jason Quote Link to comment
racerx Posted September 16, 2008 Report Share Posted September 16, 2008 Never use silicon in carbs..they will eventually melt away due to vibrations and heat and all that junk will get into your intake and engine and even clog your jets, hello! Quote Link to comment
datsunaholic Posted September 16, 2008 Report Share Posted September 16, 2008 Kinda hard to clog the jets since it's below the carb. I've seen folks put the carb gasket (the top one) together with RTV and that did clog up everything. Still, RTV on a carb gasket isn't a good idea. Just get a roll of gasket paper from the local parts store and cut your own. That's what I do. I generally put everything together dry now except where there are converging joints or cork gaskets. I used to coat everything and wondered why it all leaked. Quote Link to comment
Phlebmaster Posted September 16, 2008 Report Share Posted September 16, 2008 I used bathroom caulking once.....:lol: That was stupid! I had a 67 Plymouth fury (my first car) with a leaky carter 2 barrell. It was a mess!!....I was 15. lol Quote Link to comment
sdsurf Posted September 17, 2008 Author Report Share Posted September 17, 2008 I'll get the make my own shiz... thanks!! Quote Link to comment
datzenmike Posted September 17, 2008 Report Share Posted September 17, 2008 Go to a dollar store and buy a hand held hole punch. Think that's what they are called. Look kind of like pliers, spring loaded and will punch small holes in cardboard. If you have ever tried to cut small bolt holes with scissors or a sharp knife you'll know that's BS. With the hole punch you can nibble any size hole and they look good. Just trace the gasket out. Quote Link to comment
hang_510 Posted September 17, 2008 Report Share Posted September 17, 2008 Go to a dollar store and buy a hand held hole punch. If you have ever tried to cut small bolt holes with scissors or a sharp knife you'll know that's BS. wish that worked on a HG :mad: Quote Link to comment
datsunaholic Posted September 17, 2008 Report Share Posted September 17, 2008 Go to a dollar store and buy a hand held hole punch. Sad but true, I've been using my old 60s era 3-hole lever punch on gaskets for years. Just been too cheap to go get a set up real punches. Quote Link to comment
racerx Posted September 19, 2008 Report Share Posted September 19, 2008 Hey, if it works, then don't mess with it...the hole puncher may not be the "ideal" tool but hey if it works then more power to you. Quote Link to comment
fisch Posted September 19, 2008 Report Share Posted September 19, 2008 I used a dewalt scroll saw and it did a groovy job. But I bet a holepunch would be just as good and will try it next time! Quote Link to comment
OL YELLER Posted September 19, 2008 Report Share Posted September 19, 2008 OK Guys..here is a really OLD MAN tip..if ya don't have a punch...take the gasket material you have...lay it over the area you want to make the gasket for, take a small Ball peen hammer and GENTLY tap the material around all the holes...this will mark the location perfectly..go a bit farther and a little harder with the hammer and, it will take the material out of the hole and there you have it....this is as I say quite an OLD backyard trick taught to me by my Father probably when I was in Jr High..(1954-55)....been doin it this way fer years....saves ya some time and ugly exacto lookin holes...Ha Ha Ha Quote Link to comment
datzenmike Posted September 19, 2008 Report Share Posted September 19, 2008 My first auto shop project in '65. Had to use paper hand towels. Quote Link to comment
Phlebmaster Posted September 20, 2008 Report Share Posted September 20, 2008 My first auto shop project in '65. Had to use paper hand towels. Must have been Brawny! The quicker gasket upper..... :lol::lol: Quote Link to comment
