lynchfourtwenty Posted September 21, 2008 Report Share Posted September 21, 2008 ok :) what about clutch an trans? Link to comment
datzenmike Posted September 21, 2008 Report Share Posted September 21, 2008 You are basically turning a Z22 into a L22B. It will now be an L series motor and any L series tranny will fit and sit properly in the tunnel. The clutch depends on which size flywheel you have. The Z22 used a 225mm and Z22 4X4s were 240mm. Car L20Bs used 200mm and truck L20Bs were 225mm. All six bolt flywheels will interchange so you have lots of choices. If you could find a blown up L20B with 5spd attached you would have everything you need except for a new Z22 crank. BTW you need a Z22 rod??? They are the same as an L20B rod. Link to comment
lynchfourtwenty Posted September 21, 2008 Report Share Posted September 21, 2008 great info mike!!! i think if i do this project i want to avoid rebuilding anything.. lack of money basicly.. im sure someone will wanna do something with his block tho for sure.. jus gonna need someone with more cash then me Link to comment
