DatMo Posted March 7, 2017 Author Report Share Posted March 7, 2017 I would point first finger at shocks.They're brand new Opel gt shocks? Quote Link to comment
q-tip Posted March 7, 2017 Report Share Posted March 7, 2017 With the car on the ground how much up travel is left on the shock? Quote Link to comment
DatMo Posted March 11, 2017 Author Report Share Posted March 11, 2017 With the car on the ground how much up travel is left on the shock?Unfortunately my linkage took a shit on me the other day so I haven't really touched the car. I've also got a wink mirror I gotta put on because I can't see shit out of my fender mirrors. Quote Link to comment
q-tip Posted March 11, 2017 Report Share Posted March 11, 2017 Unfortunately my linkage took a shit on me the other day so I haven't really touched the car. I've also got a wink mirror I gotta put on because I can't see shit out of my fender mirrors. Adjust them better, it took me an hour of fucking with mind to get them right but they work great. Quote Link to comment
DatMo Posted March 11, 2017 Author Report Share Posted March 11, 2017 Adjust them better, it took me an hour of fucking with mind to get them right but they work great.That could very well be the issue. I only spent about 10 minutes and as soon as I was driving, I didn't know what I was looking at lol. Quote Link to comment
q-tip Posted March 12, 2017 Report Share Posted March 12, 2017 That could very well be the issue. I only spent about 10 minutes and as soon as I was driving, I didn't know what I was looking at lol. I have mine set so I can see some of the side of the car still so I have a point of reference. With the fender mirrors and the rear view only blind spot is right next to me on the driver's side. Quote Link to comment
DatMo Posted March 24, 2017 Author Report Share Posted March 24, 2017 I got a compression test done over at left coast Datsun and chuck told me I got a 180 on 1&2 but a 120 on 3&4 which is weird because it would usually be 1&3 or 4&2 which makes me believe I have a blown head gasket? Any input? Quote Link to comment
q-tip Posted March 24, 2017 Report Share Posted March 24, 2017 Could be headgasket could be worn rings. 120 isn't awful, it will still run. Quote Link to comment
DatMo Posted March 24, 2017 Author Report Share Posted March 24, 2017 Could be headgasket could be worn rings. 120 isn't awful, it will still run. Yeah true. I'm just praying it's not rings. Im planning to do the headgasket and if it's the valves, I'll be on the lookout. Quote Link to comment
DatMo Posted March 24, 2017 Author Report Share Posted March 24, 2017 Also I'm baffled with my linkage situation. So I handed a complete cannon manifold linkage setup to chuck but he said I was still missing some pieces because dellortos are a bit different. He said I was missing a piece for the idle adjustment. However with that said, does anyone know what I'm missing and where I could possibly get it? Here's what he's put on and it is what I had given him. I figured idle adjustment was set from those threads? Also chucks a great guy. A bit pricey but great guy and definetly helping. 1 Quote Link to comment
DatMo Posted March 27, 2017 Author Report Share Posted March 27, 2017 Update: I got a centerpull linkage that should be coming in the mail shortly. I'm bringing the car home from chucks on wed and unfortauntely the car remains to not be completely drivable. I'll be installing new trans bushings, the electric fan, a choke, the center pull linkage, and adjusting the steering. Driving it I also noticed my temp gauge flying around so I plan to ground it better as well. I really hope to be able to take this car on things but it's just so damn problematic. I also have a head gasket shop in mind down the road as well. Quote Link to comment
DatMo Posted April 1, 2017 Author Report Share Posted April 1, 2017 God damn it. Looks like I'm leaking fluids from areas around the rear main seal. Will look into it next week. Quote Link to comment
datsunfreak Posted April 2, 2017 Report Share Posted April 2, 2017 You should for real just light this thing on fire and walk away... :rofl: 1 Quote Link to comment
Draker Posted April 2, 2017 Report Share Posted April 2, 2017 Rear main is always a while your in there maintenance part. Quote Link to comment
DatMo Posted April 2, 2017 Author Report Share Posted April 2, 2017 You should for real just light this thing on fire and walk away... :rofl: Seriously. I'll get under there in the next few weeks. FUCK I HOPE ITS NOT. Either way, I still want to do more. You guys think one 10 inch spal fan will keep the engine cool? Quote Link to comment
datsunfreak Posted April 2, 2017 Report Share Posted April 2, 2017 You guys think one 10 inch spal fan will keep the engine cool? It wouldn't here. In Socal, maybe... With that fancy aluminum radiator, probably... Quote Link to comment
DatMo Posted April 5, 2017 Author Report Share Posted April 5, 2017 Needed some positive energy into this car so I installed the electric fan. I think it'll be just fine. Here's clearance. I potentially may have cut the pulley too short but I made sure it wasn't flush. lol my saw blade blew up and actually ruined a lot the paint in my engine bay so Ima gonna touch up. Damn it. Anyways. Pics. I guess? Also, I noticed that when I took off my heat shield from t3, the back of it seems to have enabled a gas leak of some sort? I feel like this could be my fault because I did not run a gasket. Do you guys run gaskets with your heat shields? I run no gasket to the manifold and heat shield but I do run the carb spacers and a gasket against the spacers to the carbs. Quote Link to comment
q-tip Posted April 5, 2017 Report Share Posted April 5, 2017 Yeah, need a gasket on the heat shield. Fan looks good though. Quote Link to comment
DatMo Posted April 5, 2017 Author Report Share Posted April 5, 2017 Yeah, need a gasket on the heat shield. Fan looks good though.Thanks I'll see where I can get one asap. Maybe just make one too. Quote Link to comment
DatMo Posted April 6, 2017 Author Report Share Posted April 6, 2017 I'm gonna head to Europeans next week since I'm on spring break and get a heat shield gasket. I've also got one of my studs replaced today and a few other small knicks in the engine bay fixed up. I want to mount my coil better as it plays around so I figured I'd zip tie it to the bracket with an industrial zip tie. Quote Link to comment
q-tip Posted April 7, 2017 Report Share Posted April 7, 2017 Try and actual coil mount, that will hold it better than a zip tie. Quote Link to comment
DatMo Posted April 7, 2017 Author Report Share Posted April 7, 2017 Try and actual coil mount, that will hold it better than a zip tie. Loll very true. I actually have one and it fits very well for the 3/4 coils I have but the only want that actually works is the smaller size one. Quote Link to comment
DatMo Posted April 18, 2017 Author Report Share Posted April 18, 2017 I turned on the car the other day and it sounded decent. Still trying to figure out this dual choke method. I had one setup that was a universal and it had u shape towards the front of the car to pull the choke but that added too much difficulty to the choke so I may have to find some sort of other setup. I'm fixing a lot of the wiring. I did it myself and really had absolutely no idea what I was doing but now I understand more. I'm trying to make a hazard switch but the damn thing keeps burning. I'm running a hot wire from the fuse box to a switch and I'm grounding it so I figured I'd need a relay and haven't gotten around to it. On top of that. I need to adjust my clutch and still get rid of the slack in my throttle cable to be just right so I'm gonna do that. Radiator may be punctured so I gotta run some water through it to find out. Always some shit. Quote Link to comment
Lockleaf Posted April 18, 2017 Report Share Posted April 18, 2017 Get a wiring diagram of the car and copy the hazard circuit. If you can't read a diagram, you can't get it right on the car. Copy down the entire hazard circuit and only the hazard circuit on to another piece of paper. Start at battery, go through fuses, etc. Draw everything until you get to ground. Now you are ready to wire it. 1 Quote Link to comment
DatMo Posted April 18, 2017 Author Report Share Posted April 18, 2017 Get a wiring diagram of the car and copy the hazard circuit. If you can't read a diagram, you can't get it right on the car. Copy down the entire hazard circuit and only the hazard circuit on to another piece of paper. Start at battery, go through fuses, etc. Draw everything until you get to ground. Now you are ready to wire it. The thing is that I've got an aftermarket wiring harness from ez wiring. I initially had them working and went through one wire at a time on the car because everything from the day running lights to inside lights had been working. As far as a diagram, the harness is for gms so it was no help. I'm going to attach my brake light wires and see if what I read was correct. Otherwise, I don't see why it wouldn't work if the wire is getting power and I plug it to a switch with a ground. Quote Link to comment
