DatMo Posted August 23, 2016 Author Report Share Posted August 23, 2016 Fuel pump is on but not too sure where I want to mount my regulator and I'm still waiting on my psi gauge. My new dash is complete just needs quick trims for perfect fitment on the radio. As far as everything else, it's going smooth. I placed the the fuel pump with brackets bolted down to my battery box but it shall hold well. Also gonna drill a new hole on the side of my battery box for battery cables to make it a bit more efficient. Then just to tune carbs etc. I'm so close yet so many details are bothering me lol Quote Link to comment
DatMo Posted August 23, 2016 Author Report Share Posted August 23, 2016 Also I'm scared because the mount is on there really well but it's a fuel pump and it's just on the outside? I mounted it onto the battery box I have. Lemme get some pics on here Quote Link to comment
DatMo Posted August 23, 2016 Author Report Share Posted August 23, 2016 Whatcha guys think? it seems a little low and exposed right? Quote Link to comment
r0p0doe Posted August 23, 2016 Report Share Posted August 23, 2016 Whatcha guys think? it seems a little low and exposed right? You're fine I have mine mounted on or near the rear Xmember if I remember correctly Quote Link to comment
DatMo Posted August 23, 2016 Author Report Share Posted August 23, 2016 You're fine I have mine mounted on or near the rear Xmember if I remember correctlySweet! I mounted it differently so it's better now. It's maybe 3/4 of an inch lower but the diff is lower and the exhaust so I think I'm okay. Thanks bro! Quote Link to comment
Laecaon Posted August 24, 2016 Report Share Posted August 24, 2016 Normally mounted at a different angle... but if it works... Not the cleanest look, but most dont get the chance to look underneath. Quote Link to comment
DatMo Posted August 24, 2016 Author Report Share Posted August 24, 2016 Normally mounted at a different angle... but if it works... Not the cleanest look, but most dont get the chance to look underneath. I totally agree which is why I took it all off and mounted it much much better and looks tons cleaner lol. I'm not sure what to do with the rubber line because it still has that wrap from each side of the hardline. But I also bought some bolt clamps to hold down so it doesn't get near the driveshaft or anything. Quote Link to comment
DatMo Posted August 24, 2016 Author Report Share Posted August 24, 2016 pics! it scares me a bit that it's a little lower and of course, after this picture, i cut a bigger hole for battery wires and painted the box again and used some wire holders and a grommet. also got my fpr in and i like the spot! I just need a spot to put the brass piece that allows for the gauge. I have a dash gauge so I'm not sure how it works or hooks up. I'll have to wait until it comes I guess. Quote Link to comment
Laecaon Posted August 24, 2016 Report Share Posted August 24, 2016 I would get an elbow for the side of the pump facing the diff. Quote Link to comment
q-tip Posted August 24, 2016 Report Share Posted August 24, 2016 I would get an elbow for the side of the pump facing the diff. This Quote Link to comment
DatMo Posted August 24, 2016 Author Report Share Posted August 24, 2016 I'm gonna look at an elbow tomorrow then. As far as it getting near the diff, it's held down with these wire clamp things. Quote Link to comment
DatMo Posted August 25, 2016 Author Report Share Posted August 25, 2016 So bad news. I've installed my new fuel pump and cleaned all my lines and no gas seems to be entering even the clear filter that I put right after the tank. I put 5 gallons in and I can hear the electric fuel pump working. Please help :( Quote Link to comment
Draker Posted August 25, 2016 Report Share Posted August 25, 2016 Wired backwards or clogged lines. 1 Quote Link to comment
DatMo Posted August 25, 2016 Author Report Share Posted August 25, 2016 Wired backwards or clogged lines.I'm not sure how it could be wired backwards because there's an obvious ground and power and they're both connected as supposed to and I figured it wouldn't work properly if not? As far as clogged lines, they're all clean because I took them out and shot fluids and air through them Quote Link to comment
Draker Posted August 25, 2016 Report Share Posted August 25, 2016 I'm not sure how it could be wired backwards because there's an obvious ground and power and they're both connected as supposed to and I figured it wouldn't work properly if not? As far as clogged lines, they're all clean because I took them out and shot fluids and air through them Ok so the lines are clear. Pull the hose and stick it in a gas can. See if it pumps it out in the direction you expect. I'm not familiar with at pump what so ever so I can't say if it could actually pump backwards. First just try to pump a gas can. 1 Quote Link to comment
DatMo Posted August 26, 2016 Author Report Share Posted August 26, 2016 So I took a break from fuel system and engine shit cuz I'm just worn out as fuck but I finished my dash and I'm super stoked. Pics coming Quote Link to comment
DatMo Posted August 26, 2016 Author Report Share Posted August 26, 2016 here's some oics. Quote Link to comment
Laecaon Posted August 26, 2016 Report Share Posted August 26, 2016 here's one oic. Fixed. 1 Quote Link to comment
DatMo Posted August 26, 2016 Author Report Share Posted August 26, 2016 Fixed.Lolll I like it Quote Link to comment
Draker Posted August 26, 2016 Report Share Posted August 26, 2016 Interested to see how that fits in the car. Like the gauges! Quote Link to comment
DatMo Posted August 26, 2016 Author Report Share Posted August 26, 2016 Interested to see how that fits in the car. Like the gauges!ill post pics when I get it in and done. Thanks! Speedhut works nicely Quote Link to comment
r0p0doe Posted August 26, 2016 Report Share Posted August 26, 2016 ill post pics when I get it in and done. Thanks! Speedhut works nicely Why not the stock dash? I always have mixed feelings about different dashes Quote Link to comment
DatMo Posted August 26, 2016 Author Report Share Posted August 26, 2016 Why not the stock dash? I always have mixed feelings about different dashesI would have to hack the shit out of it for my radio that I want as well as have to buy an external piece that wouldn't look suitable for my other gauges. With this, I got everything I want and more. Plus, it matches the wood in the rear. Quote Link to comment
banzai510(hainz) Posted August 26, 2016 Report Share Posted August 26, 2016 stock dash is alwasy perfect and get more money when selling 1 Quote Link to comment
Lockleaf Posted August 26, 2016 Report Share Posted August 26, 2016 stock dash is alwasy perfect and get more money when selling Then it's a good thing he decided not to hack the shit out of it, isn't it? 1 Quote Link to comment
