720_Jeff Posted April 19, 2022 Report Share Posted April 19, 2022 8 hours ago, Datsun pickup said: How would I be able to take it apart and rebuild it? I believe, there is a small metal ball inside, be sure to not lose it. Otherwise, not so tough to figure out. Quote Link to comment
datzenmike Posted April 20, 2022 Report Share Posted April 20, 2022 If wires cut that's the problem. Don't take switch apart, fix the wires. Quote Link to comment
Datsun pickup Posted May 7, 2022 Report Share Posted May 7, 2022 (edited) I fixed the wires and it didn’t fix anything. What should I do next? Should the hazard lights be connected with the stop lamp fuse? Edited May 7, 2022 by Datsun pickup Quote Link to comment
datzenmike Posted May 7, 2022 Report Share Posted May 7, 2022 Stop lamps and 4 way hazard switch are on the same 15 amp fuse. It's 12 to the right or four to the left from the right side. It's been so long what exactly is not working?? Quote Link to comment
Datsun pickup Posted May 7, 2022 Report Share Posted May 7, 2022 The hazards work just fine, but the turn signals don’t work. Would it be the turn signal switch? Quote Link to comment
paradime Posted May 7, 2022 Report Share Posted May 7, 2022 Although you won't find it in the owner's manual, intermittent disfunction of the turn signals is a common feature on all Datsuns. 1 Quote Link to comment
Datsun pickup Posted May 17, 2022 Report Share Posted May 17, 2022 Is the turn signal switch the culprit of the problem? Quote Link to comment
datzenmike Posted May 17, 2022 Report Share Posted May 17, 2022 On 5/7/2022 at 11:36 AM, Datsun pickup said: The hazards work just fine, but the turn signals don’t work. Would it be the turn signal switch? 12 minutes ago, Datsun pickup said: Is the turn signal switch the culprit of the problem? First the 720 has a known problem with the 4 way emergency flasher switch. Turn ignition on and signal left or right. Make sure the emergency 4 way switch is all the way OFF, now slowly push the switch towards ON. When the turn signal starts working, stop. Doesn't help? Swap the 4 way flasher with the turn signal flasher. If turn signals start working then the flasher was bad. Quote Link to comment
Datsun pickup Posted May 18, 2022 Report Share Posted May 18, 2022 I replaced the flasher relay and it didn’t help anything. Quote Link to comment
datzenmike Posted May 18, 2022 Report Share Posted May 18, 2022 There was no guarantee it was the flasher and why I said to swap with the 4 way flasher. Now you have a new but unknown if reliable part. Can you do what I said to try with the 4 way flasher switch? Quote Link to comment
Datsun pickup Posted May 31, 2022 Report Share Posted May 31, 2022 I have switched the relays and it messed the system up more. Quote Link to comment
datzenmike Posted June 1, 2022 Report Share Posted June 1, 2022 Do the turn signals work? Quote Link to comment
Datsun pickup Posted June 21, 2022 Report Share Posted June 21, 2022 No, the turn signals do not work. Quote Link to comment
Datsun pickup Posted June 21, 2022 Report Share Posted June 21, 2022 I switched the relays and the hazards blinked faster. What would cause this? Quote Link to comment
datzenmike Posted June 21, 2022 Report Share Posted June 21, 2022 It just proves that the flasher units are good. Do your temp and gas gauges work? If yes, then the fuse, which also powers the signals is ok. So the problem is in the turn switch. Quote Link to comment
Jethrow86 Posted December 1, 2022 Report Share Posted December 1, 2022 I’m guessing it’s the switch but no clue, my right blinker works fine while my left doesn’t do anything. It used to make a single click and the blinker light would come on the dash for a split second but the tail light itself didn’t do a thing. Now when I try to turn my blinker on i don’t even hear a click or get a dash light for it. Again it’s only the on left side, that’s what’s really getting me Quote Link to comment
datzenmike Posted December 1, 2022 Report Share Posted December 1, 2022 720 turn signals and headlight switch are problematic. Short of replacing it, try flushing with spray electrical contact cleaner. The lube put on at the factory dries and also collects dust. Might be a good idea to remove the column assembly entirely to get at it. Quote Link to comment
