split collar shafts.
DatMo
The bolts will snap long before you crush the strut tube, they are thick enough to support the front end weight.
Too large a diameter will tighten but not grip the tube. Too small will work just fine but not too too small.
  • Replies 34
This.
I'll just go with something that's 9/16. it's 5.6 so i assume it should be good. cant find anything that's 1.59.. even though I'd think a 5 inch perimeter is common.
Well i actually found 1.5.
I'm thinking that may be too small....
edit.
 I saw that the 280zx struts is 2.07 but the 2.0 id clamp worked.
I found 40mm clamps which comes out to 1.57 so I'm getting these to fit the 1.59.
I'm hoping it all works.
Well the shafts weren't tight enough so i shaved off a bit of them on the tips so that it tightens more.
They came out perfect and I'll be posting pics as soon as my car is done :)
  • 2 months later...
