konig209 Posted August 5, 2014 Report Share Posted August 5, 2014 So i got irritated of everyone simply saying google or search ratsun. Not enough detail. So i made a video. Kbai.Thanks to datson4life.thanks to mklotz70 for the video.mklotz edit thanks :DHow to re-index a 521 or tortion bars on a datsun.: 16 3 Quote Link to comment
mklotz70 Posted August 5, 2014 Report Share Posted August 5, 2014 Good vids! That the easiest I've ever seen a torsion bar come out! The clips are all short enough, you could make one vid. PM if you want to do that, but don't have a way. 1 Quote Link to comment
flatcat19 Posted August 5, 2014 Report Share Posted August 5, 2014 Nice rake job. Great tutorial. Should be stickied to make for an easy find. 1 Quote Link to comment
konig209 Posted August 5, 2014 Author Report Share Posted August 5, 2014 Yeah i know i tried to edit them all into one video but it wont let me. It flips the videos upside down. 1 Quote Link to comment
]2eDeYe Posted August 5, 2014 Report Share Posted August 5, 2014 Nice rake job. Great tutorial. Should be stickied to make for an easy find. X2 ....... 2 Quote Link to comment
datson4life Posted August 5, 2014 Report Share Posted August 5, 2014 Cool, ur phone takes good video 1 Quote Link to comment
mrbigtanker Posted August 8, 2014 Report Share Posted August 8, 2014 Dude the video is gone now.wtf 1 Quote Link to comment
flatcat19 Posted August 8, 2014 Report Share Posted August 8, 2014 Dude the video is gone now.wtf Weak sauce. 1 Quote Link to comment
konig209 Posted August 8, 2014 Author Report Share Posted August 8, 2014 Sorry klotz moved a lil to fast on me with his edit.ive been working and didnt have time nor wifi to download the edit. 1 Quote Link to comment
mklotz70 Posted August 8, 2014 Report Share Posted August 8, 2014 Not sure what happened. I didn't delete it or even touch it yet, but it's gone. I had kept it from being public, but I don't know why it disappeared. I'll reupload it and send you another link. 1 Quote Link to comment
mklotz70 Posted August 8, 2014 Report Share Posted August 8, 2014 Let me know when you've got it up on your youtube channel. :) http://youtu.be/9ReqlebBFwU 6 Quote Link to comment
konig209 Posted August 8, 2014 Author Report Share Posted August 8, 2014 Not sure what happened. I didn't delete it or even touch it yet, but it's gone. I had kept it from being public, but I don't know why it disappeared. I'll reupload it and send you another link. Thanks. Ill be sure to download it asap this time. 1 Quote Link to comment
datson4life Posted August 9, 2014 Report Share Posted August 9, 2014 Let me know when you've got it up on your youtube channel. :) It slipped out at 3:50 1 Quote Link to comment
dat521gatherer Posted August 10, 2014 Report Share Posted August 10, 2014 Sweet. 2 splines if I heard correctly. Now I can delete my 10 bookmarks on how to do this. 1 Quote Link to comment
konig209 Posted August 10, 2014 Author Report Share Posted August 10, 2014 Yessir 2 spline. 1 Quote Link to comment
banzai510(hainz) Posted August 4, 2015 Report Share Posted August 4, 2015 Icehouse just did one spline and readjust the bolt lower again. should be more than enuff 1 Quote Link to comment
ELSOBDatsun Posted September 16, 2015 Report Share Posted September 16, 2015 2 spines drops it how far? 1 Quote Link to comment
4perrev Posted February 8, 2016 Report Share Posted February 8, 2016 Nice work. Makes it easy and clear! 1 Quote Link to comment
521wasabi Posted March 10, 2016 Report Share Posted March 10, 2016 I reindexed my torsion bars in my 521. I turned the bars 2 notches towards the engine. Put everything back together....and front sits higher now. Obviously I went the wrong way with turning the bars. Repulled bars and turned them away from the engine. But now the adjusters at the other end of the bars (end that is bolted back in place) is too far out to bolt. How do I get around this? 1 1 Quote Link to comment
Lockleaf Posted March 10, 2016 Report Share Posted March 10, 2016 Put a Jack under the control arm and lift it. Bar should turn. 2 1 Quote Link to comment
420n620 Posted March 10, 2016 Report Share Posted March 10, 2016 I reindexed my torsion bars in my 521. I turned the bars 2 notches towards the engine. Put everything back together....and front sits higher now. Obviously I went the wrong way with turning the bars. Repulled bars and turned them away from the engine. But now the adjusters at the other end of the bars (end that is bolted back in place) is too far out to bolt. How do I get around this? I found that you only need to move the torsion bar spring 1 spline. This way your able to keep the original tension on the bar or close to it when you adjust it back to the original specks. And you'll be able to adjust it without using a jack. 2 1 Quote Link to comment
LRB Posted September 5, 2018 Report Share Posted September 5, 2018 Team, How can I reindex after I’ve completely removed the lowers arms and I am now putting it all together. I didn’t mark anything before taking them off fml..... Any suggestions would be much appreciated, thanks! LB Quote Link to comment
]2eDeYe Posted September 5, 2018 Report Share Posted September 5, 2018 I would put the arms back to what I thought they were and install them. See where it sits and adjust from there. You will need to play with the clocking a bit anyways to dial in the ride height you want to run. Quote Link to comment
LRB Posted September 5, 2018 Report Share Posted September 5, 2018 Thanks for the quick reply. Sounds like a plan. I’ll have to figure it out from there. I’m also trying to look for a factory marking on the lower arm center hole, there should be one wouldn’t you think? Thanks again, LB Quote Link to comment
]2eDeYe Posted September 5, 2018 Report Share Posted September 5, 2018 They were all likely set the same at the factory using a fixture or gauge or the like. Quote Link to comment
