mahi2010bv Posted July 23, 2014 Report Share Posted July 23, 2014 So went to the mechanic (again, seems she doesn't want to give me a break) cause I smelled tranny oil which I have been religiously checking and today for some reason it was low. Mechanic says i busted the housing of the speed sensor. I know it's a 81 and there isn't a speed sensor, but he told me it's a mechanical one. Now I live in puerto rico and called all the junkyards in my area and nothing. Went to a speciality shop for nissans and what they had was the pinion but no housing. Anyone know where I can get this rare part? Quote Link to comment
datzenmike Posted July 25, 2014 Report Share Posted July 25, 2014 The pinion is the plastic gear (usually colored for the number of teeth it has, BLACK would be 17 tooth) that is driven off the transmission mainshaft. The round part, with the O ring oil seal that the speedometer cable screws onto, is called the pinion sleeve. A12 4 speed sleeve................... 32707-18000 A14/15 4 and 5 speed sleeve.... 32707-H7300 About $20 Quote Link to comment
mahi2010bv Posted July 28, 2014 Author Report Share Posted July 28, 2014 Thanks for the reply @datzenmike. I see that you have parts numbers but what store is that for so I can order it Quote Link to comment
datzenmike Posted July 28, 2014 Report Share Posted July 28, 2014 It's called the Nissan Motor Company. You can use the numbers to cross reference to another supplier, maybe? 1 Quote Link to comment
mahi2010bv Posted July 30, 2014 Author Report Share Posted July 30, 2014 I have an automatic, does that make a difference in sleeves? Quote Link to comment
mahi2010bv Posted August 18, 2014 Author Report Share Posted August 18, 2014 @datzenmike what would be the part number for the a15 3speed sleeve? I can't find wonder if you might know Quote Link to comment
