...datlife......always Bustin' Nuts......
Well.....
Guess this is how things go for me....
Rings didn't show up yesterday.....called....."wait till tomorrow"..they say....... :fu: ..I say...I paid extra shipping....
Regardless......I'm at their mercy......
Option 2 if ring set does not show up...
......Tonight..........rip engine out tonight and TEAR...IT...APART.....
......Tomorrow......rebuild existing engine and drop back in......
......Sunday..........Break-In........
Is this wishful thinking??.... :unsure:
  • Replies 1.4k
im sure you can get it done, with some help of course!!
i think i got out of prior plans this weekend so it looks like i will be available all weekend to lend a hand  :w00t:  :w00t:  :w00t:
i will be over tonight after work with some beer ready to help..
  • Like 3
Turns out.....
.......an engine is not needed.......
.....................he drove up here from Cal Poly because some shop diagnosed it as a bad valve in the head....
He brought it up on a trailer......got here about 7ish....
It still ran and didn't sound as bad as I thought......
...........so I had him rip the valve cover off to check valve clearance........
Shocking........6/8 valves were waaaay too tight.......
....time to learn how to adjust valves........
Running....... :thumbup:  :thumbup: ....much better.......
..........but as soon as I drop the idle to where it should......be it starts fuckin' up......
.........................carb dip tomorrow... B)
  • Like 3
2.2 is gonna go in 5Teezy for break in.....
.......................then I'll probably put it up for sale.....
Here is how Maxwell's went.......
http://community.ratsun.net/topic/58298-a-dime-richer/page-4?do=findComment&comment=1160015
Engine progress will commence throughout the week.........
the guy used to be on here... i forget his screen name.
 had that cream colored kingcab on titans that was really low when he was done with it.
seems he got out of the datsun scene after some personal stuff came up? his kingcab has been on the List a few times now.
Guy in SoCal bought it and was gonna ship it to Troy Ermish.....
......he ran into someone that knows me and told him to call me........
...........so he had it towed here for me to get running so he can fly up and drive it home......
We'll see how this story unfolds.....
Thx Q-tip.....tow truck driver said he thought a fish tank broke inside the car when he raised the front to get it on the trailer..............
Got to take a look at this thing last night.......
This is how it showed up.........I took the cap and wires off only.........
:confused:
Pulled the valve cover off and the spark plugs out to check timing marks..........
I put a ratchet on the crank bolt and started to spin it to TDC.....
..................I made it about 15* before I hit something solid............and it would not turn no mo.......
So for shits and giggles I spun it back the other direction..........same shit........10-15* and BAM....solid.........
Gotta getta hold of the owner and see what he want to do next.......
Engine dismantling......numbers do match on this car :thumbup: .........or......
Engine swap...................
look at the cam lobe position when it loocks up.
you know close to TDC the first 2 lobes will be in the 10 oclock and 2 oclock position. if not the look at the other lobes and maybe hitting a piston or cam sprocket was whay off whn install or not set to TDC when removed ect....... was motor apart then reinstalled and not running since then
History would help
trans out of gear ? llift up on jack to eleininate trans issue
maybe the chain tensioner is wedeged/poped out jammed?
I doubt transwould be in gear. he works on cars for a living........... and in my experiences when a tensioner pops out the motor would bearely move 5* but  im sure not every situation is the same....
  • Busta Nut changed the title to ...datlife......always Bustin' Nuts......
