cgovia Posted September 11, 2008 Report Share Posted September 11, 2008 what does it take to put on titain rims on a 620 (tires,lugs etc) Quote Link to comment
]2eDeYe Posted September 11, 2008 Report Share Posted September 11, 2008 Check the FAQ in General Discussion (or click the link in my sig) ;) Quote Link to comment
Bleach Posted September 11, 2008 Report Share Posted September 11, 2008 http://forum.ratsun.net/showthread.php?t=2129 I machined the wheels to fit. The link above doesn't say how, but I used a 1/2 " router bit with the ball bearing guide. ($25 part) route 1/2 width and 1/2 inch depth. Fits good. Stock acorn style lug nuts. ">" type="application/x-shockwave-flash" width="425" height="350"> I adjusted mine slowly and did it 1/16th inch at a time. Quote Link to comment
Fineline Posted September 11, 2008 Report Share Posted September 11, 2008 Not much. If you have the drum brakes I believe they bolt right up. If you have a disk truck I think you have to either bore out the center of the wheel, use a spacer (which requires longer wheel studs. Dorman p/n# 610-403), or turn down the spindle assembly. Quote Link to comment
]2eDeYe Posted September 11, 2008 Report Share Posted September 11, 2008 You have to do the same work for the drum brakes as you do for the disc. Quote Link to comment
Fineline Posted September 11, 2008 Report Share Posted September 11, 2008 Good to know. Damb you guys are quick! Quote Link to comment
Bleach Posted September 11, 2008 Report Share Posted September 11, 2008 somebody needs to get off the internet and get back to work! :D Quote Link to comment
]2eDeYe Posted September 11, 2008 Report Share Posted September 11, 2008 What I can't do both? :D Quote Link to comment
moparvwfreak Posted September 11, 2008 Report Share Posted September 11, 2008 2eDeYe;80141'']What I can't do both? :D sure ya can. just don't let the boss catch ya :D then again if YOUR the boss who cares right?? Quote Link to comment
motavated Posted September 11, 2008 Report Share Posted September 11, 2008 By how much do you have to open up the center? What is the size? I looked at the facts but it Dont say... Quote Link to comment
]2eDeYe Posted September 11, 2008 Report Share Posted September 11, 2008 About 1/4" all the way around according to Bleaches post. Quote Link to comment
motavated Posted September 11, 2008 Report Share Posted September 11, 2008 Aight Thanks man! Around here there is a set for 200 dollars and My bro the tire shop man can bore out the centrers for 15 each!!!! So I might by them... Quote Link to comment
Bleach Posted September 11, 2008 Report Share Posted September 11, 2008 I bought mine for $150 and they were perfect. I promptly curbed 3 of them. :( Quote Link to comment
