4perrev Posted March 11, 2015 Author Report Share Posted March 11, 2015 (edited) Ok, as promised, here's the inside of the engine: Looks like a new head gasket so somebody took care of the old gal. Pistons have very little carbon on them. It all could be wiped off with a bit of solution and a rag. The cam chain and sprockets look brand new, along with the cam guides: The head was super clean all the way round. It is a W53 head with the smog inserts. Hoping to get lucky and find a peanut head, but it's just the old round chambers. This one's not cracked though! The cam and journals were nice a shinny with no rust on em'. The water pump looks to be maybe a year old and all the passages were beautiful and calcium free. Every screw or bolt came out free without a hint of breakage. All in all, looks to be a great motor to build up. Now just have to decide which head to put on her. A87, U67 or the W53 with the smog liners ground out. I have to do some research in the engine section to see who has the biggest valves! Edited May 14, 2019 by 4perrev Quote Link to comment
hobbes_the_cat Posted March 12, 2015 Report Share Posted March 12, 2015 Unless the A87 is peanut chambered you'll probably want to go with the U67. Should be bigger valves and no smog liners. A87 came with big or small valves so you'll need to measure em. Edit: you sure that's a w53? Never heard of a smog w53. W58 was the smog head. Quote Link to comment
4perrev Posted March 12, 2015 Author Report Share Posted March 12, 2015 Yeah, upon closer look....it is a W58. Was trying to remember as I was writing the post after pulling the engine apart. Thanks. 1 Quote Link to comment
DottiBlue Posted March 13, 2015 Report Share Posted March 13, 2015 Lookin good. Nice score on that engine. Quote Link to comment
4perrev Posted March 14, 2015 Author Report Share Posted March 14, 2015 Thanks Dotti. She's getting there. More work to be done tomorrow, just have to wait until the weekends is all. Quote Link to comment
4perrev Posted March 20, 2015 Author Report Share Posted March 20, 2015 (edited) So after a long awaited time, I finally picked up my main hoop for the roller today. This is just the beginning as I still have to order the seats in order to place the hoop where it needs to go. Once they show up, I can set the right position and mock up the rest of the cage. Here is what I used to get the measurements for the shop to bend up the hoop. Keep in mind, I have not fit this in the car yet, so the two 10 degree angles may be a little off. Once I get sometime to get in there (weekend) I will give more details. Anyways, here's the chart: And the main hoop: Edited May 14, 2019 by 4perrev Quote Link to comment
4perrev Posted March 23, 2015 Author Report Share Posted March 23, 2015 (edited) Got down and did some interior work today. Thought I might see how the dash looks: So with this mounted, I saw the pedal box that was rusted and ugly as sin: Put it in to mock up the pedals and see how they fit: Not too bad, but that pedal box needed some serious attention and she went into the blaster for a new look: After it was all blown off, it got a new coat of paint to pretty things up: Still coming along slowly!! Edited May 14, 2019 by 4perrev 3 Quote Link to comment
q-tip Posted March 23, 2015 Report Share Posted March 23, 2015 Progress is progress! 2 Quote Link to comment
4perrev Posted March 23, 2015 Author Report Share Posted March 23, 2015 So true, so true! Just wish it was not a weekend away! 1 Quote Link to comment
4perrev Posted March 28, 2015 Author Report Share Posted March 28, 2015 (edited) Got the old dash cleaned up and painted. Probably won't see very much of this once the pad and everything on it, but it's rust free now! Took this picture of the ram on the back of the big Dodge. Funny thing is, everything else was a reflection off the window. Weird and cool all in the same. Edited May 14, 2019 by 4perrev 1 Quote Link to comment
4perrev Posted April 19, 2015 Author Report Share Posted April 19, 2015 (edited) My little girl saw the sun yesterday. had a chance to pull her out and do some work on the roof. There was a big bondo patch up there and got me curious as to why it was so big. How many licks does it take to get to the center of a bondo patch? Well, quite a few in this case. This is why she came out of the garage, because sanding bondo in a closed space powders everything. Anyway, here's the aftermath and all the front windshield lips are back to original without the pitted rust spots. Turning to the rear window, it got worse. I guess she had been sitting outside for a good period of time (as most of these girls do). This one was a little more tricky as it was in the corner and really rusted out. So, I cut out a new lip and got it welded in. The hard part was trying to keep the original window lines without blowing through what I just replaced. The sanding wheel was to big, so I used a cutoff wheel that was already worn down and fit the curve perfectly. Nice and slow until the shape to form. Starting with: Ending with: And this kids, is why we don't put fiberglass in daddy's car! If you remember, I sanded out the front floors to replace them with pans. Well, I looked at the rear and thought that I might just leave it since nobody will ever sit back there (might not even put in a rear seat). There was an end sticking up and with a little tug, the whole floor came up. I guess the fiberglass was laid over rust because the floor is in bad shape. Lastly, I leave you guys with this picture. Here is the test fit of the main hoop. Seats are on order and should show up next week. Then I can get down and fab the whole cage!! Edited May 14, 2019 by 4perrev 1 Quote Link to comment
datsunfreak Posted April 21, 2015 Report Share Posted April 21, 2015 Had some time last night and worked on another paint idea. It's a little rough due to Photoshop, but you can get the idea. What do ya think?? The X's are just place holders for logos. While I'm impressed with the photoshop job, it wasn't 100% necessary... ^_^ 3 Quote Link to comment
4perrev Posted April 21, 2015 Author Report Share Posted April 21, 2015 I tried to find 510 race cars, but this one eluded me. I used the z-car as an idea. Thanks for the pictures though. It gives a much better idea of the whole car!! Quote Link to comment
datsunfreak Posted April 21, 2015 Report Share Posted April 21, 2015 I tried to find 510 race cars, but this one eluded me. I used the z-car as an idea. That scheme was used on all the Bob Sharp race cars of the era, including the 280Z and also a 610 and a B210. :thumbup: The 510 I posted photos of was driven by Paul Newman, and were I to do that livery I'd have to put that name on it.. ^_^ Quote Link to comment
4perrev Posted April 22, 2015 Author Report Share Posted April 22, 2015 Thanks for the info (history). It would almost seem to have to wear the Newman name as a tribute car. Will keep all in mind when finalizing the paint scheme. Can always count on a Ratsun member for good advice! 1 Quote Link to comment
4perrev Posted April 25, 2015 Author Report Share Posted April 25, 2015 (edited) Well the Sandy-man showed up today with presents. My seats finally arrived. The brackets fit like a "T" in the original holes, but didn't come with mounting bolts. So I'll be off to Home depot for some hardware. Here's the goods: Brackets with double locking sliders: These are Corbeau CR1's with 3-inch five-points: Now I can get down to finishing the back half roller/cage. Measured up and need to get some pipe!! Edited May 14, 2019 by 4perrev 1 Quote Link to comment
4perrev Posted May 3, 2015 Author Report Share Posted May 3, 2015 (edited) Big Saturday worth of work. Got down and finally replacing the rear floors. Went back to the parts car and pulled out a good floor. Surprising how bad that parts car looks, all the floors were good! I guess it all works out in the end. Here's the stuff: Now it's on to the good stuff. I bought a notch cutter from Harbor Freight for $40 bucks (I think).It wasn't too bad, although the cut was off by a bit. Just had to make a shim under the holder and she went pretty straight after that. (Thanks to the guy on Youtube who made a video of the fix)! Never did any notching, so the measuring was a little weird in the beginning, but made it through all the cuts so far. First off was to weld plates to give the rear truck wall some support: I also put down some plate steel on the floor where the main hoop sits to give more support. It's mostly done and all I have left is the side bars and the harness bar. Completely forgot to measure when I test fitted the seats, so I guess I gotta put one back in to get the right height. Not too hard though. Must say, this route (even with the notch cutter) it turned out to be under $400 bucks. The Autopiler bar was 600 something without shipping and I installed an X-bar to the rear shock towers also. Here's the goods so far: Edited May 14, 2019 by 4perrev Quote Link to comment
Evaded Posted May 15, 2015 Report Share Posted May 15, 2015 Awesome work so far! Eric Quote Link to comment
4perrev Posted May 16, 2015 Author Report Share Posted May 16, 2015 Eric, thanks for the good words! Need more time, dam-it!! Here's an update to the roll bar fabrication. Just one more bar left. Cut out the spare tire holder because the bottom was rusted out and didn't really want to go through all that patching. So, I cut it out and went with a flat blank off plate to cover it. Will give pics when I snap one of the completed patch. Quote Link to comment
jrock4224 Posted May 26, 2015 Report Share Posted May 26, 2015 are u gonna fuel cell this car ? i see a stock tank ... Quote Link to comment
4perrev Posted May 26, 2015 Author Report Share Posted May 26, 2015 (edited) Got into the old Photoshop again and came up with a new design for the dime. I know I've had a couple draw up, but I think this one might be the right one. It's different and completely brand new. Trying to go with a rally theme. Comments / critiques?? Edited May 14, 2019 by 4perrev Quote Link to comment
LimpMode Posted May 26, 2015 Report Share Posted May 26, 2015 Got into the old Photoshop again and came up with a new design for the dime. I know I've had a couple draw up, but I think this one might be the right one. It's different and completely brand new. Trying to go with a rally theme. Comments / critiques?? YES!! Thats a good one. I like that radius from white to black Quote Link to comment
hobospyder Posted May 26, 2015 Report Share Posted May 26, 2015 Except the corporate logos I like it Quote Link to comment
DaBlist Posted May 26, 2015 Report Share Posted May 26, 2015 Got into the old Photoshop again and came up with a new design for the dime. I know I've had a couple draw up, but I think this one might be the right one. It's different and completely brand new. Trying to go with a rally theme. Comments / critiques?? I see three different vertical angles of strips, not sure that would look good to the eye when the car is in motion Quote Link to comment
jrock4224 Posted May 26, 2015 Report Share Posted May 26, 2015 are u gonna fuel cell this car ? i see a stock tank ... ???? Quote Link to comment
