78 Sr20det 620 Salvage title to boosted!
5t341tH
Thanks for the tips guys.
So I did some mickey mouse repairs. I put some jb weld into that missing chunk and then I tapped the hole. Used a threaded rod instead of a bolt to secure the water pump.
hopefully it holds. I am going to test it today.
  • Replies 107
By the looks of it you don't really have a flat surface for the gasket to sit on between the bolt and the water passageway so the water is probably coming from that. Redo the patch and kinda lump it over so you can carefully sand it down to level. Give that a try and see if it works?
thanks for the input guys. I finally got it to not leak! just used a gob of silicone on that particular hole before sealing it.
Since I had everything apart, I decided to upgrade the alternator. Grabbed an 02 Saturn alternator and modified it to fit. I also grabbed a 92 saturn alternator as well since that was what everyone used, but the 02 one fit much better. No water inlet clearance issues. I used a 720 v belt pulley sans external "fan"
It just needed the lower alternator mount grounded down a bit and a turnbuckle for adjustment. I'm not sure how others have used just a turnbuckle successfully but I needed an additional bracket. I used the stock bracket and cut it down to size. The belt needed for my alt was 7445.
new alt and new radiator is so nice B)
and here it is all together
So far so good. Lights are definitely brighter now with the new alternator. Engine on, I get 13.8V. Not much difference compared to the stock alternator I had (13.3V) but anything helps. I haven't driven too far yet, but it seems the new radiator cools much better than the cruddy old one
  • 3 years later...
need to upload pics from my phone. Will get to it asap!
old l20 engine out
WTJuksG7V8LO15JiVHINbocGGkotyGagjqZVxHMx
8Zvz-Mm-FT1VvX5qcL63k1nwbXVcYQQyW_YIfqox
O3IvNZWrcUSCLnf8XadhIykJhZs12dDyaxRvB8IE
engine bay painted with rustoleum hammered
boES224-REkHwjRdZRBod7DzDsf2HpEU-5PEzbuw
sr20 test fitted in place to see clearance
xY-QVa1siA2RyxvXXTS1lrdpOkiXCAYbr9Pu02FC
engine fits with plenty of firewall clearance (or so I thought)
_tpjRQK3osDx6TARKlJkPw9NlpSqxRAIprg9q9Dd
2rt6Tt5ifeIca-mOM2R_bOpd-KS2w5vfUpHBoQh7
L79FUVvGdcDzOeB5QR97V8BrpYTqayJDwy0wTjug
bought a new exhaust manifold for clearance of the steering
h3USp7x1bnC3xng17xwfptyuFVG7y0t0Xf6e8DgR
Lt-og6qGzKjbL5OC4jHAj-99j9jRgV2XZS9dRbDC
easy to say there needs to be modifications
BcJhe4l4fbW8kL1R7rwsqfiYriVtjxA4xwx3VSau
for some reason, engine mounts come in two different thicknesses
5i-hBwOhahI01VjtaWfgqWS_cPxKcmLXvWGcPAdE
MPWihcfEJW_p7ewEn9VFvZpQYbfielkkpiJA-oeV
transmission mount needs to be lengthened since it is off by 1.5"
5P7_tFulvYR3YbHPq9wOaslBaWDvatco6Z-c3lRD
zzvSmJzNurymPcQQI02z4S3R5QZc53pnjbw6gx_Q
exhaust off the back of the turbo will need to be customized as it hits the brake hardline (as well as other things)
6czvcu1tRf-2GdE3PGDaT4w5Zb8ToIIa-S8U-IuD
FBBVakLVNnmRSa2gd_MjlPTT8eq8SdzcgyPgE_KU
but engine is bolted in and I am happy
8HDoMp1P_9QKb2Yw0nWvwhqirXXcHOy9KC3vEyaO
I did the centerlink flip with the TJ inserts. it was a damn pain to drill through those two arms. But I still have clearance issues with the oil pan. This is with the steering straight ahead.
MS86_oZnkuzgB-6nldgPYgJzYmIbt5IhaujVUaAr
yAD6Jcodud55LlaZTc-Y-3z_s-bPvEpT0nKAdV9B
the water neck inlet needs to be shortened
OL6aULovEU0gR3DauTcpM5A7NBrASg5naDU_dRky
as does the air intake pipe. It needs to be reclocked
z_hupyU6-RAfT5atUMRXTP53EY9OsdG-BHNwgLTt
Edited by 5t341tH
modified the crossmember to meet up with the 620 transmission mount
UXje7GcJ2rcXZ-0VP_tMk9BTQDAA1Il-FGOtCEVB
G0L3r8koKf5xXYkAlojAqqu7upI7lMCts-K-T9oR
boxed it up for strength.
62oeo67BgiCh8Le0tMNXMqUuFYX2ufOk-cLkAuaE
WBiIVyoa4UbHVr8lIQ1rLjEAWxx-vnKRvwTVihUb
xo01sRS8r4ll5UibycGJyPNFixHYeoFRAae_dJFU
got the inlet pipe reclocked and the waterneck shortened
6h45exC02GViby2aLBIhk8ajuktD2-VWT_gNOZGB
ZRQHylVlGiSaNLK67zhxf2eE_raJKEfnpS2oz4dP
used a 240sx radiator. test fitting
5b30h_72WSStGAoo9ggwg1OZQXNOFL9S5Xt9Pijg
GTrjUnmFdOWbR745cSnaYFDqkVAP0mb2z1ZxeD8I
good clearance for the shroud and fans
02Ms2S1hjYrHRXWQ6bJnadNebhX6Jxcd1jx5FqG8
had to relocate the coolant drain over because it was hitting the frame where the bumper mounts
2KqCFMX3nPFbB4RRv4wfm3_M4HmMKg2HBKTG2maE
BDzuDjObtxt3w1ZoesiSMRECJNRQr0P02h27qFlN
radiator stood up too high, so I had to shave away the bumper brackets and drill two holes for the pegs to slot into
Q_AXAezaX7I23ETGS_z6CC3iOoBySANiGUHDWv_Z
7bq-wpOdsjD69qEZZjwNEcJr4qXWh_Ki1HnbbAm5
got it down to where I believe the hood will clear it
lACX0pmkZWOp-DxTFclzFcrYrBK2UjzxbI3GeuHU
got a one piece driveshaft made from the old one. cost only 210 bucks!
yyiwddJFnW0L3dAtcJ5vsWTPrqyCLT103UT3Alb5
radiator and intercooler final mounting situation
MwYAnXzZr8PIJ5_HngaSC4BHCKtOO5-OI3d_79jK
got the new clutch in and ready to mate with the transmission one final time
VNUZZMbg8WUwXH_PYCiREfjv7oZbnFPRWaqKA7Ah
after engine and transmission is bolted together forever, the engine now hits the firewall
GazG1zBRSytZOfkT0KAsCLgmp3FPezJt6KS28XHc
Uj5MMkHOHIf746QcAXTdb1BH3clXzWnI4Wx_MrI-
dUvZzIt6Irxw6O-cKzOuFqDaSlxhL6P_xG6KQ-be
I had to slot the engine mount brackets to allow enough movement to bolt everything down. But everything now is bolted together and I can start making a custom turbo elbow, wastegate actuator mount, intake coupler, AN fuel lines and intercooler piping
more to come! let me know if the pictures don't work
Edited by 5t341tH
Clearance for the engine mount brackets. Needed to grind it away to clear the turbo
VedjlgSt1l5nQHtOHhre2lu4odzkc7by2t7u8nwL
Final resting spot for the radiator
wVUe2BxrNOYXcJajlQZN2XOBqQRlbmWvfFlK1YMj
i had to slot the holes on both the brackets so it could slide around more.
zA3hwhsoIi0_SY1flvWmYgJsP37jmS5T20zk0EJW
ZxSo2zpoVeYCsuyyuuuDx707p1vWNTkdWNvEeRJt
ordered intercooler piping and will attempt making my own routing
Edited by 5t341tH
6 hours ago, ]2eDeYe said:
Looks good in there.
I am working up a trans cross member, but you seem to have it handled.
So it fit and then didn't fit? How did you modify the motor mounts? That is the one pic I cannot see.
When I had the transmission bolted on but without the flywheel and clutch on, it fit without hitting the firewall. When I installed the flywheel and clutch and then bolted the transmission in, it would hit the firewall. I had to hammer the firewall a bit to dent in enough room to fit
how's the progress on your alternator mounts?
Edited by 5t341tH
Slacking... ?
21 minutes ago, datzenmike said:
The flywheel and PP would have no effect on or off as far as how the engine trans fitted together.  Engine/trans must have been forward the first time and back too far the second time for some external reason. Weird.
Likely something was bolted together tightly before the final position was set.
I know my motor sits a bit different after trying to pull the trans from underneath. That doesn't work with the KA/SR clutch BTW, easiest to pull everything.
Edit: Just noticed, that shorter rubber motor mount is not the correct mount.
I went to the auto parts store and found hoses that fit perfectly
P11fl1WCctGmXME_I_VrrKG3hJXdjVfAZStq3P10
TbB5p8nlZ_HM6AYvv7sSeUhuMsyfrc4g_irW03vb
shifter location vs stock. Looks like I need to cut it back a little bit and weld up the old spot
3wYzlJ-UMi1v49BQAM6wtlbmdkZvlfPsE3zaEfRK
99_WfekYI4zQcugmUCUyNavxE19ACMoLujT-0ON4
BTXcE5DzUJjxCCgwzb9ftp9qbYk0k26s2M578Amc
Also started doing my intercooler setup. I am mocking up how I will route the piping. still waiting on some couplers to come in.
compressor outlet is 2", compressor inlet is 2.5", intercooler is 2.25", intercooler piping is 2.5", and throttle body is 2.75"
so I had to use plenty of reducing couplers with this whole setup.
lS6rdG-nK_9C5RBIPLCFmNghR3IImX9GX_2fh5tL
1lpsbRQscgUBtw1bq2_-hdcdElxPR-ZzxOImV4mv
still have to save some money so I can buy my wiring harness from "the wiring specialties." It is a plug and play harness with relays all built in with all new OEM connections. Fuel pump I am planning to use is from FiTech 40015. I purchased it but it is not in stock until next year. Nice thing about this fuel pump is it is in-tank and will be much quieter than an external pump. Also it looks super clean IMO
Edited by 5t341tH
15 hours ago, Stoffregen Motorsports said:
I use the Tanks INC pumps. No, they don't look as nice as a cool billet aluminum piece, but they are much less expensive.
Isn't it nice to find hoses that fit? I hate having to splice hoses with couplers.
I do love my hoses. So glad they let me in the back and pick through their selection. I checked out tanks inc on their fuel pumps. The price is not much different than the one I bought. Mine was $220
