skyc110 Posted May 15, 2014 Report Share Posted May 15, 2014 unlike the stamped 521 bezel ( if not , the top screw holes will guid ), the 520 is not . hope to be guided based on the ( pressed in ) and the ( pressed out ) round screw hole . is the shown R or L ? the top screw hole is pressed in , bottom is pressed out thanks Quote Link to comment
Guest Rick-rat Posted May 15, 2014 Report Share Posted May 15, 2014 what happened to the pic of the packages? Quote Link to comment
ggzilla Posted May 15, 2014 Report Share Posted May 15, 2014 So which ones is left side - pressed in or out? Quote Link to comment
MicroMachinery Posted May 15, 2014 Report Share Posted May 15, 2014 what happened to the pic of the packages? There's plenty of pics of 'packages' online if you're really jonesing. Quote Link to comment
Guest Rick-rat Posted May 15, 2014 Report Share Posted May 15, 2014 There was a pic of the packages with part numbers on them, found some part numbers and was trying to help identify R/side and L/side Quote Link to comment
skyc110 Posted May 16, 2014 Author Report Share Posted May 16, 2014 still I have it , but unfortunately I got them out to inspect them , then I couldnt return them back which one goes to which packaging !!!! hope that u understand me, as no RH , LH stamp on them Quote Link to comment
ggzilla Posted May 16, 2014 Report Share Posted May 16, 2014 62305-28001 is the LH part 62306-28001 is RH Quote Link to comment
skyc110 Posted May 16, 2014 Author Report Share Posted May 16, 2014 thanks ( ggzilla ), but that is not my Qs . my Qs is how to differentiate the bezels ( not the packages ) Quote Link to comment
wayno Posted May 16, 2014 Report Share Posted May 16, 2014 Can anyone tell from these photos which one sticks out, bottom or top? Quote Link to comment
wayno Posted May 16, 2014 Report Share Posted May 16, 2014 If I were to guess, I would say this is left, because the bottom looks like it sticks a little farther towards the middle/center. Quote Link to comment
XXL Posted May 16, 2014 Report Share Posted May 16, 2014 The one you have pictured is driver side (left side) of truck based on what is screwed onto the front of my '68. Quote Link to comment
skyc110 Posted May 16, 2014 Author Report Share Posted May 16, 2014 thanks ( XXL ) , thats what I'm after ( so the pressed in hole is in the top one ) Quote Link to comment
XXL Posted May 16, 2014 Report Share Posted May 16, 2014 thanks ( XXL ) , thats what I'm after ( so the pressed in hole is in the top one ) Yes, top is an innie, bottom is an outie. Quote Link to comment
