bonvo Posted September 8, 2008 Report Share Posted September 8, 2008 anyone know the the amprage rating on the fuseable link? i would like to replace it with an inline fuse but i need to know the amprage rating Quote Link to comment
Guest jaimesix Posted September 10, 2008 Report Share Posted September 10, 2008 I do not understand why, but all the Datsun books I have avoid telling the fusible link's specs. I got a used one of a junk car. If you want to make your own, best bet iss to call the dealer and asking them. Talk to parts and ask them, they can check in their micro files. Jaime.________________________________________________ Quote Link to comment
mklotz70 Posted September 10, 2008 Report Share Posted September 10, 2008 You can buy fusible links at most auto parts stores. The size is based on wire gauge. They are designed more to protect from the long, slow load than instaneous loads. When you buy a new pos batt cable.....if you get one with the small wire connected to the main term with the big wire......the little one is a fusible link. This ought to help some :) http://www.madelectrical.com/catalog/fusible-link.shtml Quote Link to comment
datzenmike Posted September 10, 2008 Report Share Posted September 10, 2008 Here ya go: Wire color and rating Pink 30 amp Green 40 amps Red 50 amps Yellow 60 amps Black 80 amps Blue 100 amps Quote Link to comment
zerow Posted September 10, 2008 Report Share Posted September 10, 2008 Ye olde 1973 Datsun 610 service manual calls out for two different ratings: Brown 0.3 sq. mm. (0.0005 sq. in.) 11A Continuous Current Max Current (fuse melts within 5 sec) Approx 60A Red 0.85 sq. mm. (0.0013 sq. in.) 26A Continuous Current Max Current (fuse melts within 5 sec) Approx 250A Quote Link to comment
ppeters914 Posted September 11, 2008 Report Share Posted September 11, 2008 This ought to help some :) http://www.madelectrical.com/catalog/fusible-link.shtml Mad Electrical Rocks! Quote Link to comment
