CFHdatsun77 Posted May 6, 2014 Report Share Posted May 6, 2014 called a l20b head? or is it A87? sorry its a dumb question im sure. Reason im asking is im looking for a new head for my l20b. found this post on craiglist. http://portland.craigslist.org/mlt/pts/4449434695.html Quote Link to comment
EastBay521 Posted May 6, 2014 Report Share Posted May 6, 2014 u67s are nice. they came with w58 aswell Quote Link to comment
TENDRIL Posted May 6, 2014 Report Share Posted May 6, 2014 second from the bottom looks to be shaved quite a bit. 1 Quote Link to comment
dr.feltersnatch Posted May 6, 2014 Report Share Posted May 6, 2014 L20 came with several different heads. They are known by their casting number. W53 w58 u67 a87 etc. Some have bigger valves than others and some have bigger ports. Some are open chambered and some are closed. Olddatsuns.com has a pretty good breakdown of whats what. Cruise over and read about head id and if you still have questions then ask away! 1 Quote Link to comment
dr.feltersnatch Posted May 6, 2014 Report Share Posted May 6, 2014 I would love to have the datsun 1600 valve cover if he was closer Quote Link to comment
ggzilla Posted May 6, 2014 Report Share Posted May 6, 2014 Olddatsuns.com has a pretty good breakdown of whats what. Cruise over and read about head id and if you still have questions then ask away!I don't see that at http://olddatsuns.com/ L20B came with U67/N58 or W58 heads. In Australia came with V91 heads. U67 dry manifold, square port exhaust W58/N58 wet manifold, round port exhaust Valve sizes intake/exhaust (mm) 42/33 L20B 42/35 L20B Quote Link to comment
laotsu Posted May 6, 2014 Report Share Posted May 6, 2014 I don't see that at http://olddatsuns.com/ L20B came with U67/N58 or W58 heads. In Australia came with V91 heads. U67 dry manifold, square port exhaust W58/N58 wet manifold, round port exhaust Valve sizes intake/exhaust (mm) 42/33 L20B 42/35 L20B what do you mean by dry/wet manifold. My understanding is that a "dry" manifold is only an air guide with fuel being delivered directly. I know Datun aint doing that on the L20b. Quote Link to comment
ggzilla Posted May 6, 2014 Report Share Posted May 6, 2014 Means that the head has coolant ports going into the manifold. Is there another name for it? Water-heated intake manifold? Quote Link to comment
bananahamuck Posted May 6, 2014 Report Share Posted May 6, 2014 You should try to stay with the nicest one that matches your exhaust ports,, unless he has a exhaust manifold (and Y pipe) you could buy also. Bigger valves / larger ports won't really be noticed on normal day to day driving. Quote Link to comment
datzenmike Posted May 6, 2014 Report Share Posted May 6, 2014 A87 open chamber(round port Square port) $90W58 open chamber(round port round port) $75W58 semi peanut chamber(round port round port) $75210 simi peanut chamber(round port square port) $60 I assume you want it for the '77 listed in your profile??? If so the L20b from '75 through '77 used a U-67 head on all cars and trucks. After '77 a W58 was used. You want a U-67 head with square exhaust ports to properly match your exhaust manifold. The best match is the A87 head. You do NOT want the 210 head which is for an L16 and has smaller ports and valves. The W58 have round exhaust ports. You'll note that the A87 has coolant ports just below the two pair of round intake runners. Your U67 doesn't have these and has the intake and exhaust manifolds joined together under the carb. This allows hot exhaust to warm the intake air. Don't worry the '77 intake does not have these matching ports and the passages will be sealed off when the manifold is installed. Your L20B cam and rockers can be swapped in... try to keep the rockers in the same position they came out of. 2 Quote Link to comment
ggzilla Posted May 7, 2014 Report Share Posted May 7, 2014 Where can I buy the A87 for $90? Quote Link to comment
dr.feltersnatch Posted May 7, 2014 Report Share Posted May 7, 2014 I don't see that at http://olddatsuns.com/ there is a box that says quick links right under the red 620. click where it says sss head id. there is a break down of casting numbers and their attributes. Quote Link to comment
dr.feltersnatch Posted May 7, 2014 Report Share Posted May 7, 2014 Where can I buy the A87 for $90? the craigslist ad he linked to has one. called a l20b head? or is it A87? sorry its a dumb question im sure. Reason im asking is im looking for a new head for my l20b. found this post on craiglist. http://portland.craigslist.org/mlt/pts/4449434695.html Quote Link to comment
datzenmike Posted May 7, 2014 Report Share Posted May 7, 2014 Can't tell much from this picture. You would have to see the casting numbers to be sure Top two are likely the W58s as they have round exhaust ports. The second one is for sure as it has the exhaust liners. The top one is round and no liners but maybe removed as the second one has two missing and one crumpled up. The bottom two could be anything except a W58 and not likely a U67 as they do have coolant posts for the intake. Quote Link to comment
dr.feltersnatch Posted May 7, 2014 Report Share Posted May 7, 2014 my u67 has coolant ports. sure they were added at some point but they are there. Quote Link to comment
