izzo Posted September 8, 2008 Report Share Posted September 8, 2008 Some reason the turn signals do not work. The hazard switch works fine, and the lights blink as they should. Headlights, tail lights seem to work fine. But just not the turn signals. Is it the turn signal module? Only think i could think of. As when i turned the hazards on the lights came on so i assumed it should as well. Quote Link to comment
hang_510 Posted September 8, 2008 Report Share Posted September 8, 2008 Is it the turn signal module? if the contacts are clean then its most likely the culprit, only couple $$ Quote Link to comment
izzo Posted September 8, 2008 Author Report Share Posted September 8, 2008 The contacts on the turn signal lever itself, or something else? Quote Link to comment
hang_510 Posted September 8, 2008 Report Share Posted September 8, 2008 The contacts on the turn signal lever itself, or something else? that too, but more specificly the contacts on the can. poor electrical connections are the reason for most issues. check the fuse box as well. if that fails, maybe you need this... http://kalecoauto.com/index.php?main_page=product_info&products_id=6 Quote Link to comment
