haze Posted April 22, 2014 Report Share Posted April 22, 2014 here are a few pics of my rat..... .....and here is the situation like i said she is a rat and i like her as a rat however i just moved the the california coast (about 100 yards from the beach to be exact) from austin texas and i am trying to figure out a relitively simple and affordable way to neutralize all the rust that is on her that does not involve dismantling her and sand blasting all all the pieces. i am aware that rust typically comes from the inside out but was wondering if there are any alternitives. i spent alot of time and money getting her to be mechanically sound and now i am afraid a couple of years on the coast will turn her into a red pile of dust also i have been trying to do my own leg work on this conundrum but for some reason my interweb speeds have been about as slow as molasas in december for a little over a week now Quote Link to comment
DanielC Posted April 22, 2014 Report Share Posted April 22, 2014 "I am trying to figure out a relitively simple and affordable way to neutralize all the rust that is on her that does not involve dismantling her and sand blasting all all the pieces." If you can figure this out, you will be rich. There is no miracle way to make rust go away. Iron likes to combine with oxygen, when wet. You can do this to remove rust from parts, http://community.ratsun.net/topic/3012-electrolytic-rust-removal/?hl=electrolysis But that requires removing parts from the truck, and submerging them in a plastic tub. You can also put parts in a container, with molasses, and that will remove the rust. With either process, the rusted metal is gone. You will need to replace missing metal. And then you have to get the good metal clean, and prime with a good epoxy primer. 1 Quote Link to comment
ggzilla Posted April 22, 2014 Report Share Posted April 22, 2014 ^^^ this Enjoy the truck now while saving to buy a non-rusty one in a couple years Quote Link to comment
haze Posted April 23, 2014 Author Report Share Posted April 23, 2014 this stuff looks interesting....... http://www.rustbullet.com/Products/Automotive/Automotive.asp especially after watching this video maybe an extreem clean/pressure wash/ degrease/ detail job on the underside then a sand to mostly bare metal on the the outside then coat the whole damn thing with a lplv gun, pressure pot, brush, and roller? then afterwards bondo mirrors and windsheild and finally a touch up with more of this rust stuff? Quote Link to comment
520 gasser Posted April 24, 2014 Report Share Posted April 24, 2014 You need 3 things to make rust Air Water Steel If you get rid of one rust canot happen. So when you lived in Texas you did not have a lot of water in the air. Witch slowed down the rusting. Now you live right next to the ocean so you need to get rid of air. There are a couple of ways to do this. You can rubberized the underside of the truck this will keep both water and air form reaching the metal. They also have a body wax that you can buy the gun for it has a long thin wand that you can snake into doors, rocker panels, A pillers this will keep water and air out as well but if it is applied where water will be splashed on it like from a tire you will have to re apply it every year in that spot. And you can always paint every inch of the truck. So you have a couple of things you can do just depends on what look you are going for Quote Link to comment
