Lockleaf Posted August 30, 2021 Report Share Posted August 30, 2021 It seems like any one of those calipers would be sufficient for the entire car 😁 Quote Link to comment
datsunfreak Posted August 30, 2021 Author Report Share Posted August 30, 2021 55 minutes ago, Lockleaf said: It seems like any one of those calipers would be sufficient for the entire car 😁 Probably... 😋 Quote Link to comment
dimlight65 Posted August 31, 2021 Report Share Posted August 31, 2021 6 hours ago, Lockleaf said: It seems like any one of those calipers would be sufficient for the entire car 😁 Yes, but after fading the the brakes on this car sooooo many times in the past, I want "Mondo Ultra Super Mega Over Kill" brakes! Quote Link to comment
datsunfreak Posted September 1, 2021 Author Report Share Posted September 1, 2021 Covers for rear speed holes done... 1 Quote Link to comment
dimlight65 Posted September 2, 2021 Report Share Posted September 2, 2021 On 8/30/2021 at 1:08 PM, Lockleaf said: It seems like any one of those calipers would be sufficient for the entire car 😁 Holy crap! They showed up at the shop today! And as the bishop said to the actress, "I had no idea they were THAT huge!" 1 Quote Link to comment
datsunfreak Posted September 2, 2021 Author Report Share Posted September 2, 2021 (edited) Speed hole covers installed. I am really digging these... Also put another coat of POR15 on the floor in some key spots, and went over the roll bar again. Did not take photos because it still mostly looks like it did before... 😁 And we put a coat of POR15 on the fuel tank mount box thingy. Did not take photos because... I forgot... 😁 Edited September 3, 2021 by datsunfreak 1 Quote Link to comment
Lockleaf Posted September 2, 2021 Report Share Posted September 2, 2021 What size rims are you guys running on this again? Are you going with some custom setup Wilwood hats and small diameter rotors for those calipers or how are you setting it up? Quote Link to comment
dimlight65 Posted September 2, 2021 Report Share Posted September 2, 2021 4 hours ago, Lockleaf said: What size rims are you guys running on this again? Are you going with some custom setup Wilwood hats and small diameter rotors for those calipers or how are you setting it up? The wheels we have now are 14" Western or Shelby (or some other make, I'm not even sure!) turbines. I believe we're going to try and re-drill some Toyota '86 rotors (because that's the sauce of the calipers)... but now you have me worried about wheel clearance. To make a short story long... I don't know at this time. Quote Link to comment
MikeRL411 Posted September 2, 2021 Report Share Posted September 2, 2021 1 hour ago, dimlight65 said: The wheels we have now are 14" Western or Shelby (or some other make, I'm not even sure!) turbines. I believe we're going to try and re-drill some Toyota '86 rotors (because that's the sauce of the calipers)... but now you have me worried about wheel clearance. To make a short story long... I don't know at this time. What's the source of your sauce ? 1 Quote Link to comment
datsunfreak Posted September 3, 2021 Author Report Share Posted September 3, 2021 19 hours ago, Lockleaf said: Are you going with some custom setup Wilwood hats and small diameter rotors for those calipers or how are you setting it up? Most likely 280ZX rotors (10"), but we may try the 86 rotors (11.4") as Tim said. I did a mockup previously with an 11" rotor and Brembos and it just cleared with the 14" turbine wheel, so I am confident it will be okay with a 10" rotor. The clearance issues with Wilwoods and Brembos is less about outside diameter, and more about how the caliper tends to stick out past the wheel mounting face. So your wheels need to have clearance on the back side of the spokes. I think the fix for that will be mounting the rotors further away from the wheel, thus moving the calipers back away from the backside of the wheel. If this doesn't make sense to you, it will when we start actually trying to mount this stuff. 😋 Quote Link to comment
datsunfreak Posted September 3, 2021 Author Report Share Posted September 3, 2021 (edited) Also we considered switching to 15" rims for more clearance, but we cannot find an off-road tire for a 15" wheel that is smaller than 27" in dimeter. The current tires are 25.5" diameter and are about as big as we can run without even more fender chopping. Edited September 3, 2021 by datsunfreak Quote Link to comment
datsunfreak Posted September 3, 2021 Author Report Share Posted September 3, 2021 Ooh, just found these! Yokohama Geolander in a 26.25" diameter for either a 15" wheel or a 16" wheel. That could be fun... Quote Link to comment
Lockleaf Posted September 3, 2021 Report Share Posted September 3, 2021 What you guys said makes perfect sense, I'm just surprised a stock '86 rotor would clear anything smaller than a 15. I get what you mean about backside of wheel clearance. I had a TT 300z parts car sitting on some subaru rims when I was younger, and my parents decided to push it farther out of the way. The rim shaved the embossed NISSAN right off the front calipers..... 😄 I'm interested to see how you build the caliper brackets. Quote Link to comment
datsunfreak Posted September 3, 2021 Author Report Share Posted September 3, 2021 1 hour ago, Lockleaf said: I'm just surprised a stock '86 rotor would clear anything smaller than a 15. To be honest, if it works, I'll be surprised too... 😄 The 11" rotor just barely cleared, and I don't think there's another 1/4" to spare. So we either need to make these work on 10-11" rotors, or switch to a bigger wheel. I know you can fit 15s on the 86 brakes, so... Quote Link to comment
dimlight65 Posted September 3, 2021 Report Share Posted September 3, 2021 (edited) Ah, now I understand the e-mail I got from John about the Geolandar tires. I am not married to the 14" turbines (we're kind of exclusive, but haven't gone before a judge/preacher), so stepping up to a 15" or 16" is not out of the question. In my opinion though, the Geolandars are a tad too conservative in the tread department, but I'm afeared beggars can't be choosy. So, a set of "Open Concept" 16" wheels with the Geolandars are something I could be talked into. Edited September 3, 2021 by dimlight65 Sidewall says "Geolandar" not "Geolander" Quote Link to comment
dimlight65 Posted September 3, 2021 Report Share Posted September 3, 2021 23 hours ago, MikeRL411 said: What's the source of your sauce ? I knows a guy!😜 Quote Link to comment
datsunfreak Posted September 4, 2021 Author Report Share Posted September 4, 2021 So we are at a stopping point on the interior, due to us needing to make a final decision on what the top coat will be, so we decided today was the day the doors would go on a diet... Step 1, decided where to cut... We were kinda stuck on how to cut those round corners, then realized a 4" hole saw could do it... Then got to cutting in earnest... The toughest bit turned out to be removing the brace that holds up the vent window frame... As it sits now... Needless to say I think we removed at least half the weight of the door. Now on to do it all again... 😁 1 Quote Link to comment
KELMO Posted September 4, 2021 Report Share Posted September 4, 2021 So, no vent windows then? Probably no windows at all but hey, gotta ask. Quote Link to comment
dimlight65 Posted September 5, 2021 Report Share Posted September 5, 2021 No, one day I casually asked, "How cool would a one-piece window be?" We thought it over and came up with a plan. Then I bought a pair of these for it and threw THAT plan right out the... um, window. Quote Link to comment
]2eDeYe Posted September 6, 2021 Report Share Posted September 6, 2021 On the tires thing. UTV's and side by sides run 14"s and have a wide range of tire selection. Can get all sorts of funky 😄 1 1 Quote Link to comment
dimlight65 Posted September 6, 2021 Report Share Posted September 6, 2021 11 hours ago, ]2eDeYe said: On the tires thing. UTV's and side by sides run 14"s and have a wide range of tire selection. Can get all sorts of funky 😄 Interesting, but: A) All of them that I found were too tall (over 26") and 2) We may to have to step up to 15s or 16s to clear the calipers 1 Quote Link to comment
datsunfreak Posted September 6, 2021 Author Report Share Posted September 6, 2021 (edited) 16 hours ago, ]2eDeYe said: On the tires thing. UTV's and side by sides run 14"s and have a wide range of tire selection. 5 hours ago, dimlight65 said: Interesting, but: A) All of them that I found were too tall (over 26") and 2) We may to have to step up to 15s or 16s to clear the calipers And 3, most are not speed rated for freeway use, not load rated for this heavy a car, and often not DOT legal. This was an avenue we considered at one point. 😁 Edited September 6, 2021 by datsunfreak 2 Quote Link to comment
]2eDeYe Posted September 6, 2021 Report Share Posted September 6, 2021 I've seen them doing much faster than 50mph lol. Quote Link to comment
datsunfreak Posted September 6, 2021 Author Report Share Posted September 6, 2021 6 minutes ago, ]2eDeYe said: I've seen them doing much faster than 50mph lol. And I've done 130+mph on tires rated for 100mph, but it doesn't mean it was a good idea... 😄 3 1 Quote Link to comment
Mattndew76 Posted September 6, 2021 Report Share Posted September 6, 2021 I've seen UTV tires on Gambler 500 cars every year. They bring spares and never seem to ever have to use them., Quote Link to comment
