jwoshark Posted March 20, 2014 Report Share Posted March 20, 2014 So I just got a '73 240z and all the hoses and vaccum tubes need to be replaced,is there anywhere that has a list of exactly what i need? and also what fluids should I use (Oil, clutch,tranny) Oil filter, and do i need lead additive for gas and oil? Quote Link to comment
datzenmike Posted March 20, 2014 Report Share Posted March 20, 2014 Engine oil... 15W40 Shell Rotella or Chevron Delo 400 Oil filter... NAPA Gold, WIX, anything but fram. Transmission... (standard) 80 or 90W GL4. (automatic) DEXRON ATF. Clutch fluid... DOT 3 Absolutely no additives!!! Quote Link to comment
ggzilla Posted March 20, 2014 Report Share Posted March 20, 2014 Vacuum tubes? You mean in the radio? Valvoline 10W-40 1 Quote Link to comment
jwoshark Posted March 20, 2014 Author Report Share Posted March 20, 2014 Vacuum tubes? You mean in the radio? Valvoline 10W-40 Sorry no idea what I was thinking when I said vaccum, just all the hoses in the engine need to be replaced since they are all original. Quote Link to comment
jwoshark Posted March 20, 2014 Author Report Share Posted March 20, 2014 Engine oil... 15W40 Shell Rotella or Chevron Delo 400 Oil filter... NAPA Gold, WIX, anything but fram. Transmission... (standard) 80 or 90W GL4. (automatic) DEXRON ATF. Clutch fluid... DOT 3 Absolutely no additives!!! No additives? Wasn't this car made to run on leaded fuel? Quote Link to comment
datzenmike Posted March 20, 2014 Report Share Posted March 20, 2014 I think Nissan used hardened valve seats back then. Someone else can answer if 87 octane will do if not run premium. Quote Link to comment
ggzilla Posted March 20, 2014 Report Share Posted March 20, 2014 My 1972 Datsun was designed to run on unleaded- says so right in the owners manual. Datsun used superior metals compared to American cars. Even the steel was stronger and rusted less. When was the last time you saw a 1970-1973 American sub-compact? They rusted away long ago. Quote Link to comment
maltese Posted March 20, 2014 Report Share Posted March 20, 2014 I run premium. A shot of Seafoam every now and then. Lucas Hot Rod & Classic Car 10w40. 2500ppm ZDDP. Bosch oil filter (same as Purolator Pure One). Quote Link to comment
ggzilla Posted March 20, 2014 Report Share Posted March 20, 2014 The 1973 240Z owner's manual under "Fuel Recommendation" says to use: * 87 R+M/2 * 91 RON this is for 8.8:1 compression ratio. Gas is rated today by the R+M/2 method. If your 240Z is stock and pings on 87 octane gasoline, then adjust the timing correctly, and ensure it is not running hot. Quote Link to comment
