Suspension bushings
Z-train
  • Replies 3
I was just thinking about this and there sure is!!!! http://www.fulcrumsuspensions.com.au/SuperPro/superpro.html
Look around this site. It has some not all bushings for this truck.... You have to order them through a Tien supplier..
Edit: You can only order the front strut bar bushings and rear leaf spring bushing. But you can supposedly use a cheaper alternative for the rear posted in the facts section.... http://forum.ratsun.net/showthread.php?t=2129
What year 620?
The 78/79 trucks use mostly the same bushings as a 720, but it is never listed in the urethane catalogs.
You have to cross-reference all the part numbers individually in a standard catalog, like TRW or MOOG to verify that they are all the same. I have the books for this. Or you might be able to do it on rock auto for the cross reference.
The 72-77 620 are a completely different game. You can use generic sway bar endlink bushings for the sway bar and the T/C rods. Mklotz had some delrin upper/outer control arm bushings a while back.
Jason
