jesusno2 Posted August 31, 2008 Report Share Posted August 31, 2008 is this a ignition relay?? or starter relay?? it is preventing my car from turning over i had to jumper the two wires and bypass it. If so can i get a new one or car i just wire up a aftermarket relay? If so what kinda amprange we looking at here. Quote Link to comment
ppeters914 Posted August 31, 2008 Report Share Posted August 31, 2008 is this a ignition relay?? or starter relay?? it is preventing my car from turning over i had to jumper the two wires and bypass it. If so can i get a new one or car i just wire up a aftermarket relay? If so what kinda amprange we looking at here. Dunno how it could be any sort of relay with only one wire connected, or is there another terminal below where the black/yellow wire is connected? Where do the red wires go? :confused: Quote Link to comment
jesusno2 Posted August 31, 2008 Author Report Share Posted August 31, 2008 the 2 unhooked go to the relay the red wire hooked between them is just a jumper wire to get it to crank. Quote Link to comment
xyzalvarez Posted August 31, 2008 Report Share Posted August 31, 2008 as my dime : same shape relays... one was coming from the ignition / coil , one wire is ground for sure and the other two power... the other ones were, horn and lights i think... hope it helps...my dime came with a spiderweb as wireharness...:( Quote Link to comment
ppeters914 Posted September 1, 2008 Report Share Posted September 1, 2008 Without a 510 wiring diagram, I don't know for sure, but going through old posts, there's a B/Y wire that runs from the ignition switch directly(?) to the starter solenoid. Hainz also mentions a B/Y wire for the second set of points on a dual-point dizzy. May or may not matter, but what year car, and what year/size motor? Quote Link to comment
jesusno2 Posted September 1, 2008 Author Report Share Posted September 1, 2008 the car is a 70 motor is l20 pretty sure it a starter relay but right now i got bigger issues than that dumb thing i think i might have to do some head swaping or a header swap. Quote Link to comment
Icehouse Posted September 2, 2008 Report Share Posted September 2, 2008 Could it be the inhibitor switch? Was it an auto originally? Quote Link to comment
jesusno2 Posted September 2, 2008 Author Report Share Posted September 2, 2008 Yes it was a auto and I bet your right I wonder if having this jumper wire is gonna fry something. Quote Link to comment
