philip1 Posted August 30, 2008 Report Share Posted August 30, 2008 I'm new here but some of the older folks might recognize some of my old cars. Quote Link to comment
sean1978 Posted August 30, 2008 Report Share Posted August 30, 2008 Very cool Datsuns. I'd love to find myself an older RWD non - Z but past the early 80's seems to be very difficult to find around here. Quote Link to comment
datzenmike Posted August 30, 2008 Report Share Posted August 30, 2008 Bought a new '76. Like that stance, looks ready to back road rally. Got pix of how you fit the L20B in? Quote Link to comment
philip1 Posted August 30, 2008 Author Report Share Posted August 30, 2008 I built it to be a rally car and used it for rally cross racing here is the engine just after startup. Quote Link to comment
]2eDeYe Posted August 30, 2008 Report Share Posted August 30, 2008 That 210 is saweet :cool: Quote Link to comment
philip1 Posted August 30, 2008 Author Report Share Posted August 30, 2008 the A to L swap in the 120y B210 is really easy the car is a pl510 from the firewall forward the B310 210 is the same. The trick is the driveshaft you need a 210 automatic driveshaft because the front yoke matches the output shaft on a z 5-speed and will mate up without modification. Brakes become a weak point but since the front end is basically the same as a pl510 larger brakes are a cinch. use a pl510 radiator or you will have to notch the core support to clear an HL radiator. With this swap you will need to use an electric pusher fan because the engine is very close to the radiator 3/4 inch or less. Gees I should charge for this hehehe. Quote Link to comment
datzenmike Posted August 30, 2008 Report Share Posted August 30, 2008 the A to L swap in the 120y B210 is really easy the car is a pl510 from the firewall forward the B310 210 is the same. The trick is the driveshaft you need a 210 automatic driveshaft because the front yoke matches the output shaft on a z 5-speed and will mate up without modification.Gees I should charge for this hehehe. This would tell me that the 210 auto is longer than the 4spd. It's cool to find interesting parts that match to things never intended isn't it? Quote Link to comment
philip1 Posted August 30, 2008 Author Report Share Posted August 30, 2008 you are correct as well as the auto shaft being more stout than the manual shaft. Quote Link to comment
Guest jaimesix Posted August 30, 2008 Report Share Posted August 30, 2008 Hi. I remember your B210 very well. I think you used to post at the 1200Datsun site. I remember the avatar, I think it was the silluete of a guy with a hat. I would like to get a 4 door B210 to fix up. I love B210s, mine got stolen years ago....since I already had the coupe, want to try the 4 door. Gone to Canby??? What are you doing nowadays Datsun related? did your lowered B210 became the off road B210? Welcome. Jaime.________________________________________________________ Quote Link to comment
ggzilla Posted August 31, 2008 Report Share Posted August 31, 2008 Hi phil, long time no see. How's the Datsun scene in North Carolina? Quote Link to comment
philip1 Posted August 31, 2008 Author Report Share Posted August 31, 2008 It's been an eternity I need to make a meet again it's sparse. I will keep looking and hopefully I'll have one soon. Quote Link to comment
mike Posted October 22, 2009 Report Share Posted October 22, 2009 Ive got a question for you regarding the l swap into a b210. I found a 74 with an auto... kinda rusty but complete and the price is right... My question is will the stock rear hold up to a LZ22/5 speed or will it grenade? Motor has unported stock u67 head and stock l20 cam for now and a 32/36... Ive got a set of 40s and have been keeping my eye out for a well prepped head and cam setup (ported, bigger valves and good midrange/street cam) Also if I put 280zx struts up front will there be any custom parts that I will have to buy/make or is it a bolt on ordeal? And would the spring rate of cut stock z springs be too stiff, or is there a better junkyard candidate/donor you can think of? Im leaning more towards on road handling than rally type set up. As for the parts list in your other thread concerning swaps Im guessing that Ill need a 510 oil pan and a pedal set up... are there any suitable pedal swaps if I cant find a manual b210? Any info/insight would be great. Thanks. Quote Link to comment
zetozeto99 Posted October 22, 2009 Report Share Posted October 22, 2009 Sweet rides! Quote Link to comment
