Show me your Tool............
Every now and then I come across a tool that makes my life a lot easier.........
Sometimes the tools are new to the market and others have been out for some time.....
............I get just a little frustrated inside when a tool I don't know about is out there and I don't realize it till after the job is done......
So........if there's a tool you own that makes any job easier please share.........could be BUILT or BOUGHT........
Here are a couple to start things off.........
Snap On prybar set......
They have a button on them so you can pivot and lock in 15* increments........almost 315* of movement......
  • Like 10
  • Replies 646
One of my faves.......
MOAR LOWAR Snap on ratchet/socket set..........
With a 14mm socket on the 3/8" drive ratchets........10mm on the 1/4" drive.....
MOAR LOWAR with a 10mm on it.......
Is that a Dual80 on the right? Damn that center one is thin!
One on the right is a regular 1/4 drive flex head ratchet with a regular 10mm socket.......
One on the left is a 3/8 drive 80 tooth flex head ratchet with a 14mm socket.......
Center one is the low pro 80 tooth Snap On ratchet.....1st oic with a 14mm low pro socket......2nd with a 10mm low pro socket....
Yes........it gets in there........
Twist ratchet wrench. Not this brand pictured, but I couldn't find a pic of the correct brand. Not used very often but definitely a lifesaver when I need it.
Snap on makes a version of this that is really really nice. I need one. Theres so many places I just cant get any ratcheting action.
... and this thread is awesome, BTW.
^^....thx AJ.......gotta love tools!!
This thing. Dewalt Impact Driver. This saves me so much time (being a professional mechanic). If it's not this, it's a 1/4" air ratchet. 2 amazing tools, Lastly, Snap-On flank drive wrences. Life savers they are.
I have something similar to this........Snap-on version.......
.................7.2v and I bought mine before they came out with the clutched version.......
Hard to tell how big the Dewalt one is but looks a little bulky.........can never tell from internet oics though.....I could be way off.......
This is probably my most used tool...........it's small enough to fit in really tight spots........under dashes and such
To compliment this I also bought a couple 1/4 drive kits.......
Problem pulling cam seals in tight spaces..........
Best tool ever for this is right here..........it will save your ass
This little dingleberry slips under and behind the lip of the seal and use the rod as the fulcrum..........
I didn't have a seal to demo on right now but you get the idea...................
  • Like 6
