Stoffregen Motorsports Posted October 4, 2022 Report Share Posted October 4, 2022 6 hours ago, TotallyWrecked said: Oh apologies for verbiage. My buddy owns Wrong Era Customs which isn't too far from you. He does incredible work, and yes TIME, time is the pain and the benefit of these considerations. The pain, I am converting what was once an all original parts 520 into a Ratsun, but the j13 is trashed an L16 is going to have the same pain points as a bigger upgrade and if I'm going to basically spend the same money for a ka24e swap or an LS swap. I think it becomes what's going to be the most fun for the long term. and I'm blessed to have long chicago winters to build my patience, I figured if I wanted something done right it was going to take a year either way. but please this is exactly why I've taken to the forums here. I want to know, I want to make the best decision. I've actually heard that name. I think I was even in his shop a couple years ago. Long winters... How I miss those. I miss the snow at least. Here in Cool, we get wet, while ten miles up the road, they are dry with snow. Quote Link to comment
TotallyWrecked Posted October 4, 2022 Report Share Posted October 4, 2022 13 hours ago, datzenmike said: Agree but when there is a problem you can't diagnose and fix with a piece of fence wire and a screwdriver on the side of the road. THIS lolol is exactly why I would avoid EFI, but I'm going to do whatever is best here for nice long highway drives and seasonal reliability, since my 520 has never seen snow. Quote Link to comment
datzenmike Posted October 4, 2022 Report Share Posted October 4, 2022 Not knocking EFI as it is great for starting, running, mileage and most certainly a lot less regular maintenance than a carburetor. But if/when it quits it's an automatic tow to someone who has the knowledge and diagnostic equipment to fix it. It's VooDoo to me. Quote Link to comment
Icehouse Posted October 4, 2022 Report Share Posted October 4, 2022 I can't think of a time I've had EFI fail and leave me stranded. Yes a piece of fence wire can fix a carb because they are constantly falling apart. I'm not sure how many of you guys daily datto's with EFI swaps but that's my life. Car usually falls apart around the engine. Quote Link to comment
banzai510(hainz) Posted October 4, 2022 Report Share Posted October 4, 2022 Icehouse I got a ck engine light on my 91 Toyota oicup! I dont know what to do!!!!!!!!! I took to Vatozone and O rileys and there OBD1 adapters dont FIT. Maybe I should install a carb on there and be done with it Quote Link to comment
Stoffregen Motorsports Posted October 4, 2022 Report Share Posted October 4, 2022 2 hours ago, Icehouse said: I can't think of a time I've had EFI fail and leave me stranded. Yes a piece of fence wire can fix a carb because they are constantly falling apart. I'm not sure how many of you guys daily datto's with EFI swaps but that's my life. Car usually falls apart around the engine. Right. Almost every EFI system since the beginning of time would run in limp mode if a sensor failed. The only two situations where an EFI system can leave you stranded is if the ECU/ECM fails, or if the fuel pump fails. I've had an ECU fail, but that was because it got wet. I've also had many EFI system parts fail, like TPS or MAF, but those failing means you can still get home. Even a bad CAS will run the engine in limp mode. Quote Link to comment
Icehouse Posted October 4, 2022 Report Share Posted October 4, 2022 My 510 flooded due to window seals. As I was driving I could feel it running odd. Turned around and drove home as the MAF circuit failed. Got me home though! Fuel pump went bad in my S13. Jumpered the relay so it was on constantly and banged on the tank until it took off. Drove to work and home then installed a new one. I've had my L motor datsun's leave me stranded many times. 1 Quote Link to comment
TotallyWrecked Posted October 4, 2022 Report Share Posted October 4, 2022 still bummed but until two days ago my j13 never let me down, not even once. I like carbs because I am a caveman and I like motorcycles. but I do understand the EFI points, at the end of the day its going to come down to what engine I end up putting in the 520. 1 Quote Link to comment
Icehouse Posted October 4, 2022 Report Share Posted October 4, 2022 1 hour ago, TotallyWrecked said: still bummed but until two days ago my j13 never let me down, not even once. I like carbs because I am a caveman and I like motorcycles. but I do understand the EFI points, at the end of the day its going to come down to what engine I end up putting in the 520. I bought the oldest bike I liked that came with EFI haha. 1 Quote Link to comment
Icehouse Posted October 4, 2022 Report Share Posted October 4, 2022 4 hours ago, banzai510(hainz) said: Icehouse I got a ck engine light on my 91 Toyota oicup! I dont know what to do!!!!!!!!! I took to Vatozone and O rileys and there OBD1 adapters dont FIT. Maybe I should install a carb on there and be done with it Just put a piece of Boeing acquired tap over it. Done and done. 1 Quote Link to comment
banzai510(hainz) Posted October 4, 2022 Report Share Posted October 4, 2022 1 hour ago, Icehouse said: ust put a piece of Boeing acquired tap over it. I thought of that already!!!!!!!!!!!! 1 Quote Link to comment
banzai510(hainz) Posted October 6, 2022 Report Share Posted October 6, 2022 I swapped the airfilter light came back on after resetting the light. I reset again with new plugs and injector cleaner. light came back on the 2nd day then whent out. Why I dont know. Does injector cleaner even work? Stroffregen????????? Quote Link to comment
Icehouse Posted October 6, 2022 Report Share Posted October 6, 2022 15 minutes ago, banzai510(hainz) said: I swapped the airfilter light came back on after resetting the light. I reset again with new plugs and injector cleaner. light came back on the 2nd day then whent out. Why I dont know. Does injector cleaner even work? Stroffregen????????? I always try mechanic in a can first. Quote Link to comment
Stoffregen Motorsports Posted October 9, 2022 Report Share Posted October 9, 2022 On 10/6/2022 at 11:53 AM, banzai510(hainz) said: I swapped the airfilter light came back on after resetting the light. I reset again with new plugs and injector cleaner. light came back on the 2nd day then whent out. Why I dont know. Does injector cleaner even work? Stroffregen????????? Injector cleaner does work, depending on how bad your injectors are clogged. Whenever I use it, I double the recommended dose. High end shops use an actual injector flushing machine. 1 Quote Link to comment
banzai510(hainz) Posted October 9, 2022 Report Share Posted October 9, 2022 Ok I will double. Light came back on then went out last night 1 Quote Link to comment
thisismatt Posted October 10, 2022 Report Share Posted October 10, 2022 Not sure about Toyotas, but with OBD1 hondas you just jumper a plug with a paperclip and turn the ignition to ON to count how many flashes, then look it up 2 Quote Link to comment
Stoffregen Motorsports Posted October 10, 2022 Report Share Posted October 10, 2022 Yes, I think all OBDI systems are set up that way. And a hard reset is done by simply disconnecting the battery. Not so with ODBII. 1 Quote Link to comment
