cgovia Posted August 28, 2008 Report Share Posted August 28, 2008 theres two lines comming out of the fuel tank one is bigger than the other can some one tell me which one is the main fuel line my goon has a 32/36 on it and lines are all messed up Quote Link to comment
808DA6 Posted August 29, 2008 Report Share Posted August 29, 2008 Pretty sure larger is going to the carb and the smaller is the return. That's the route that's on my truck. -Brian Quote Link to comment
comply Posted August 29, 2008 Report Share Posted August 29, 2008 There's a return hose? Que? Quote Link to comment
datzenmike Posted August 29, 2008 Report Share Posted August 29, 2008 L20B motors had a fuel return line, but I don't think others did. It may be the tank vent that eventually connects to the PCV valve to draw away and burn the fumes. On later cars a charcoal cannister was used to store fumes when the motor wasn't running. If it's a fuel supply line then it should be submerged and will bubble if you blow in the end. If it doesn't then it's likely a vapor vent. Quote Link to comment
