Bory Posted January 23, 2017 Author Report Share Posted January 23, 2017 Evap and bulkhead 4 Quote Link to comment
Bory Posted January 23, 2017 Author Report Share Posted January 23, 2017 Master with all lines hooked up, with manual valve and a good look at the engine coolant line shock mount 4 Quote Link to comment
Bory Posted January 23, 2017 Author Report Share Posted January 23, 2017 Fuel reg installed and fuel lines 3 Quote Link to comment
Bory Posted January 23, 2017 Author Report Share Posted January 23, 2017 A/C heater lines bulkhead 4 Quote Link to comment
Fast720 Posted January 23, 2017 Report Share Posted January 23, 2017 Hey looking great So jealous ................... it's going to get busy in there , still lots of stuff to install , awesome with no Rad in there . I am considering the flush glass , I saw it done on TV also ,Bitchin rides ( Kindigit ). They did a Camaro .it does look so much cleaner. I just have so much left on the list to do. Very Nice 1 Quote Link to comment
racerx Posted January 23, 2017 Report Share Posted January 23, 2017 Looks so sexy. Is that the new 5.0 mustang engine? 1 Quote Link to comment
Bory Posted January 24, 2017 Author Report Share Posted January 24, 2017 Thanks F7- Well it's Bluprints 306, which is a 302 5.0 phat cam and aluminum heads, puts out 390 HP so I'll be frequently sideways, I guess. 2 Quote Link to comment
Bory Posted January 24, 2017 Author Report Share Posted January 24, 2017 So I'm doing led headlights just on the outside, They are a bit phat, so I have to trim the bucket a bit 2 Quote Link to comment
Bory Posted January 24, 2017 Author Report Share Posted January 24, 2017 The bucket is real shallow, not much of a bucket now, it slides over the HL real tight so I won't run the mounting ring 2 Quote Link to comment
Bory Posted January 24, 2017 Author Report Share Posted January 24, 2017 Moved the spring to the outside 2 Quote Link to comment
Bory Posted January 24, 2017 Author Report Share Posted January 24, 2017 Worked pretty well, check out the gloss black powder coated grill and bezels 2 Quote Link to comment
Bory Posted January 25, 2017 Author Report Share Posted January 25, 2017 Smoothed out sim vinyl on dash and went gloss black 5 Quote Link to comment
]2eDeYe Posted January 25, 2017 Report Share Posted January 25, 2017 That's hot! (and cold) :cool: 1 Quote Link to comment
Bory Posted January 28, 2017 Author Report Share Posted January 28, 2017 So I Frenched the front bumper, cut it in half, top to bottom, then shortened it 1-1/2" welded it back up, then shaved 3/4" off both return ends to tuck it up on the sides, also took off 1-1/2" along the whole top, to tuck it into the front pan, gave it a real euro look. Now off to the powder coating 3 Quote Link to comment
Bory Posted January 28, 2017 Author Report Share Posted January 28, 2017 The end brackets, I swopped sides and tweaked em up to make em closer to the fender, drilled new mounting holes worked great. Luckily I filled the factory holes. 3 Quote Link to comment
]2eDeYe Posted January 29, 2017 Report Share Posted January 29, 2017 Nice little touch. :cool: 1 Quote Link to comment
KoHeartsGPA Posted January 30, 2017 Report Share Posted January 30, 2017 This rig screams BADASS! 1 Quote Link to comment
Bory Posted January 30, 2017 Author Report Share Posted January 30, 2017 Showing some A/C and heater lines ran to the bulkhead 2 Quote Link to comment
Bory Posted January 30, 2017 Author Report Share Posted January 30, 2017 Throttle cable and TV cable hooked up 3 Quote Link to comment
Bory Posted January 30, 2017 Author Report Share Posted January 30, 2017 More Evap line routing 6 Quote Link to comment
Bory Posted January 30, 2017 Author Report Share Posted January 30, 2017 Also notice new lokar gas pedal! Boy am I gonna hammer that thing! 2 Quote Link to comment
