Draker Posted January 6, 2017 Report Share Posted January 6, 2017 Yeah, make sure you can access the clamps when the cab is on.. or you'll have a fun time later. :) 1 Quote Link to comment
Bory Posted January 6, 2017 Author Report Share Posted January 6, 2017 I know started to do that and it was too hard from the top, so once I have it all sorted out I'll clock em all to the same side and point em down 3 Quote Link to comment
Bory Posted January 9, 2017 Author Report Share Posted January 9, 2017 Quick little trick to make a grommet out of poly tubing, Drill a whole in your wife's plastic folding table, so the poly can slide thru, on the outside radius insert blade, pull poly up thru hole and it will leave a nice slice, right up and straight. Now go buy your wife some roses. 4 Quote Link to comment
Bory Posted January 9, 2017 Author Report Share Posted January 9, 2017 Then slide poly into place and cut it to fit tight. 3 Quote Link to comment
Bory Posted January 9, 2017 Author Report Share Posted January 9, 2017 Just showing the bead lock that was pressed into all the cooling line fittings and pipe. 5 Quote Link to comment
Charlie69 Posted January 10, 2017 Report Share Posted January 10, 2017 Sweet work again Bory. Do you ever turn out shitty work? LOL 1 Quote Link to comment
Scgreen620 Posted January 10, 2017 Report Share Posted January 10, 2017 Holy I wish I had the time the space and the money ... 2 Quote Link to comment
Bory Posted January 10, 2017 Author Report Share Posted January 10, 2017 C6- well I guess I try to catch my own mistakes- S6- I'm running real short in all 3 of those categories! Hopefully getting the cab back from glass shop this Saturday. With all the flush mounted glass and one piece side. Thanks guys! 1 Quote Link to comment
Bory Posted January 11, 2017 Author Report Share Posted January 11, 2017 Lots of fans 3 Quote Link to comment
Bory Posted January 11, 2017 Author Report Share Posted January 11, 2017 Battery tray in and over flow resivoir 4 Quote Link to comment
Bory Posted January 11, 2017 Author Report Share Posted January 11, 2017 PB AT ITS FINEST! 1 Quote Link to comment
Bory Posted January 13, 2017 Author Report Share Posted January 13, 2017 So I'm installing a wood bed, these are the extrusion rails with self adhesive rubber tape 2 Quote Link to comment
Bory Posted January 13, 2017 Author Report Share Posted January 13, 2017 Extrusion with stainless nuts installed 1 Quote Link to comment
Bory Posted January 13, 2017 Author Report Share Posted January 13, 2017 3 center slats in place 4 Quote Link to comment
Bory Posted January 13, 2017 Author Report Share Posted January 13, 2017 Making template for wheel hub 4 Quote Link to comment
Bory Posted January 13, 2017 Author Report Share Posted January 13, 2017 What I have so far, end piece is also polished stainless 4 Quote Link to comment
Bory Posted January 13, 2017 Author Report Share Posted January 13, 2017 It's gonna be stained black and very shiny! Still have to do a bit more work 5 Quote Link to comment
Bory Posted January 13, 2017 Author Report Share Posted January 13, 2017 Somebody say Tits! 2 Quote Link to comment
mklotz70 Posted January 13, 2017 Report Share Posted January 13, 2017 I wood, butt.....I pre-fir no slivers in my tits. :) .....and I pine for ass more than tits 5 Quote Link to comment
Charlie69 Posted January 13, 2017 Report Share Posted January 13, 2017 Bory that is beautiful. If you want to be fancy take some of the paint the color of the body and thin it out to make a wash for the wood. Apply same as a stain let dry between applications and the use the same clear coat as the truck body. This way you do not have to clear the wood seperately after the first 3 coats. Cover all sides of the wood to seal the wood from the weather. Or you could just do black in which the entire inside of the bed is allready Black! 1 Quote Link to comment
Bory Posted January 13, 2017 Author Report Share Posted January 13, 2017 Blu Hands you crack me up! C 6- not a bad idea! Thanks for the tip! 2 Quote Link to comment
Bory Posted January 14, 2017 Author Report Share Posted January 14, 2017 Still have that bob in the spot 3 Quote Link to comment
Bory Posted January 14, 2017 Author Report Share Posted January 14, 2017 The cap will be dropped down in the wood to flush it out 3 Quote Link to comment
