earthallen Posted January 24, 2014 Report Share Posted January 24, 2014 Hello all, First post, just finally got going on my Roadster rebuild. Quick intro, The roadster was my grandmother's then my dad's, now it is mine! In my life (33 yrs) it had not run, until last week. My dad has hauled it around the country with him and gave it to me 2 years ago. I finally got a little money and time to work on it. Very excited. 1970 1600 with a 1968 2000 engine and 5 speed slapped in it. The problem: I bought a fuel pump rebuild kit, with the spacer. It does not pump fuel. Currently when we install the diaphragm it is very loose in the pump housing. I can hold the black ring and lift the diaphragm while it is in the lower housing and feel it being pulled down and released up. With no diaphragm I can see the little arm moving up and down while cranking the engine. My thoughts/questions: Could the metal "T" be too long? Pic included with measurement in cm. Which way does the bottom rubber go? Is there a difference in the fuel pump between the 1600 and 2000 that would cause a problem? Which way does the bottom rubber go on? pics 1 and 2 Any other ideas? My best idea currently on how to fix it is to get the pump arm in its highest position, find out how much space there is between there and where it should be, cut, re-weld, hope... 1 http://i217.photobucket.com/albums/cc97/Chavez-Gomez/photo1.jpg 2 http://i217.photobucket.com/albums/cc97/Chavez-Gomez/photo2.jpg 3 http://i217.photobucket.com/albums/cc97/Chavez-Gomez/photo5.jpg 4 http://i217.photobucket.com/albums/cc97/Chavez-Gomez/photo4.jpg PS, if there is a trick to getting images into the page, I missed it on the general instructions page for uploading pics. Quote Link to comment
Jester Posted January 24, 2014 Report Share Posted January 24, 2014 You need to use the URL link in photobucket. The one on the bottom. Sounds like you have the wrong kit. Perhaps your first thought was right. Quote Link to comment
earthallen Posted January 24, 2014 Author Report Share Posted January 24, 2014 I think I just found my issue. I have no spring! I thought the spring was in the lower housing, but it appears from a post in 311's.org that it belongs on this piece between the lower seal and the diaphragm assembly. Anyone know a good source for the spring and washer seal? Quote Link to comment
Jester Posted January 24, 2014 Report Share Posted January 24, 2014 Here is a link to roadster fuel pumps. :Different part numbers Quote Link to comment
earthallen Posted January 24, 2014 Author Report Share Posted January 24, 2014 This is the image I'm seeing on 311's.org http://www.311s.org/phpBB3/download/file.php?id=13082&mode=view Am I reading it correctly and seeing that there should indeed be a spring between the diaphragm assembly (flat metal part) and the seal (black part on top) in the image Jester reposted for me? Quote Link to comment
earthallen Posted January 24, 2014 Author Report Share Posted January 24, 2014 I have confirmed that I need an internal spring and washer for my fuel pump... Anyone happen to have an extra lying around? Will pay. Thank you. Quote Link to comment
MikeRL411 Posted January 24, 2014 Report Share Posted January 24, 2014 The 1600 SAE engined roadster and the 1600 Metric [and 2 liter] fuel pumps are different which explains the part number delta. The later pumps have a thicker mounting flange but otherwise work the same, just toss the mounting bolts that fasten the early SAE fuel pump and go with threaded studs. The mounting holes will never know the difference! 1 Quote Link to comment
