What to look for in a 620 when buying
fliptrip
Hi
I'm thinking of buying a 620 which has been used as a farm vehicle
I've never owned a 620 before, just a B110
Want to know of common things to look for e.g common places for rust, particular points in the chassis for rust, things that will be a pain to replace, vs general rust/sheetmetal repair.
Also - on the plate under the bonnet - what are the measurements (in mm) for short vs long wheel base?
Thanks
  • Replies 11
Long wheel base will have 5 bed hooks, not 4, or a King Cab on it.
Fill out your profile including your location.  If in the east, rust would be a problem and availability of spare parts. Bonnet sounds Engrish or Aussie
google it - use the search - dont be lazy
but heres a start....
http://lmgtfy.com/?q=what+to+look+for+when+buying+a+datsun+620+-+ratsun.net+
Thank you - that helped immensely.
Currently it only has a flatdeck (non kingcab) so wanted to know regarding the measurements for wheelbase stamped on the plate as I can source a SWB wellside.
And yeah from NZ (so Aussie close enough!)
Ohh.... uh sorry mate. No insult intended. :lol:
Reg cab short wheelbase......................... 2,545mm
King Cab and reg cab long wheelbase...... 2,785mm
Thank you.
Rats - it's a LWB model and the wellside I could acquire is SWB, bummer, wellsides are rare as hens teeth here in NZ.
Appreciate the help
Don't buy 1
Buy 2
Pain, frustration, heartache.  But you will love it.
Rust, broken bolts and smiles per hour.
Floorboards fall out, bottoms of the doors and back of the cab like to rust as well, basically anywhere that might hold water will rust.
