BigBearFoley Posted January 6, 2014 Report Share Posted January 6, 2014 So i was looking into upgrading the disc brakes in the from of my 78 620 king cab. I search and could not find a list of items that would work for me. I know the 77's and lower have a special braket to adapt them from beebini. So I am not sure what I need since I already have discs on the front. Can some one point me in the direction of a compatable parts list or give me some advice. i know i am going to redo the rears as well before i get it back on the road so any advice there would be awesome as well. So here are my 2 questions for you: 1/ Since I have a 78620 that has disc brakes from the factory do I need the bracket to adapt different brakes. 2/ What rotors and calipers can I can I swap in to my 78 620 King Cab 3/ what do I need for the rears? is it the same as all lower years? or is it different? Thanks for your help in advance. Love the community here at Ratsun very helpful keep it up! Quote Link to comment
Z-train Posted January 6, 2014 Report Share Posted January 6, 2014 Rears are drum.Leave them as they are. Quote Link to comment
heretic Posted January 6, 2014 Report Share Posted January 6, 2014 This is exactly what I did on my 78' KC to upgrade the brakes & utilize dropped spindles: Bell-Tech D21 Dropped Spindles (2wd 4cylinder spindles 85.6' thru 97') BRAKES: 85.6' thru 97' 2wd 4cylinder D21 Hardbody truck hubs & the dust shields if you want them 85.6' thru 97' 4x4 Hardbody or Pathfinder Calipers & Mounting brackets (keep the hardware) Order new rotors for a 86-97 2wd D21 Hardbody V6 truck. BALL JOINTS: Upper ball joints are the same from 78' to 97' ... Moog PN# K9022 Lower ball joints are the same from 78' to 85' ... Moog PN# K9045 My master cylinder (13/16") & all my steering components are stock. My brakes are not soft & works as expected. Rear are fine as drums unless you're running big horse power, IMO 5 Quote Link to comment
heretic Posted January 6, 2014 Report Share Posted January 6, 2014 If you don't want to use dropped spindles then use the spindles from a 85.6' - 97' 2wd D21 Hardbody truck also. 2 Quote Link to comment
Z-train Posted January 6, 2014 Report Share Posted January 6, 2014 Dropping is truck is another story.Drums = more swept area which = stopping better.Untill they get warm.HP level is moot un-less you are competeing. Quote Link to comment
mklotz70 Posted January 7, 2014 Report Share Posted January 7, 2014 ...just to add/clarify a bit on what heretic said...........use the spindles AND the hubs/rotors/calipers/hoses from the hardbody. There isn't any other rotor/calipers that will mount on your 620 spindles......but....you can easily swap the entire spindle/hub/rotor/caliper from a mid/late 720 or hardbody onto your 620. Disconnect the two ball joints, the tierod and the hose and move everything over. The advantage to using HB parts is if you do decide later to get dropped spindles, the same parts will fit. 5 Quote Link to comment
Z-train Posted January 7, 2014 Report Share Posted January 7, 2014 One more thing,HB parts require 15 inch rims. 1 Quote Link to comment
yello620 Posted January 7, 2014 Report Share Posted January 7, 2014 One more thing,HB parts require 15 inch rims. Funny how you think that when they came stock with 14" wheels. 1 Quote Link to comment
Z-train Posted January 7, 2014 Report Share Posted January 7, 2014 There is some caliper/spindle setup that requires 15's.I know it's not 620/720's Quote Link to comment
heretic Posted January 7, 2014 Report Share Posted January 7, 2014 ...just to add/clarify a bit on what heretic said...........use the spindles AND the hubs/rotors/calipers/hoses from the hardbody. There isn't any other rotor/calipers that will mount on your 620 spindles......but....you can easily swap the entire spindle/hub/rotor/caliper from a mid/late 720 or hardbody onto your 620. Disconnect the two ball joints, the tierod and the hose and move everything over. The advantage to using HB parts is if you do decide later to get dropped spindles, the same parts will fit. EXACTLY.!!!! thanks Mike :) One more thing,HB parts require 15 inch rims. GREAT point & partially true.... ??? I think.... after doing this conversion with dropped spindles my tie rod ends BARELY rubbed the inside of stock 15" Frontier wheels at full rotational lock & spun a few wheel weights. I'm just assuming the dropped spindles had nothing to do with this. Funny how you think that when they came stock with 14" wheels. I've thought that very same thing.!!! Quote Link to comment
mklotz70 Posted January 8, 2014 Report Share Posted January 8, 2014 There is some caliper/spindle setup that requires 15's.I know it's not 620/720's I'm not positive, but it's probably the 4x4 and V6 models that required 15's Quote Link to comment
Z-train Posted January 9, 2014 Report Share Posted January 9, 2014 Mike-when I was doing my 720 upgrade to the 620,I was told that HB "gear" won't fit 620/720 steelies & ST mags.Guess who told me that? Quote Link to comment
mklotz70 Posted January 9, 2014 Report Share Posted January 9, 2014 Did I tell you that? Hmm....not sure why. The front brakes on the NL were HB and they fit stock steelies. I had D50 rims on it because they look better. I have some HB spindles here. Anyone local have some 620 spindle setups? I'll do a vid comparing everything and we'll get a final answer. If the weather were better, I'd see about going to the scrapyard. At the very least, I'll see if I can double check the HB stuff with a stock rims........soon. Quote Link to comment
Z-train Posted January 9, 2014 Report Share Posted January 9, 2014 I think it had to do with caliper clearance,maybe just ST wheel specific?But I think that would also include the steelies. Quote Link to comment
dscottdatsun Posted January 12, 2014 Report Share Posted January 12, 2014 I did this conversion (V-6 rotors and 2 piston calipers) on my '79 w/ th stock HB spindles and my stock 14" steelies fit without a problem. All the info that I have seen for the drop spindle states a minimum of 15" wheels. Quote Link to comment
mklotz70 Posted January 12, 2014 Report Share Posted January 12, 2014 Sweet. Glad to here the v6 stuff fit too!!! Quote Link to comment
5t341tH Posted July 5, 2015 Report Share Posted July 5, 2015 Thanks for the information guys. This should be stickied for us balljoint guys 1 Quote Link to comment
krecs Posted July 16, 2015 Report Share Posted July 16, 2015 hey this is juan from K-E i just finish 3 new kits for the 620 with ball joints one kit to use the 300zx calipers and 2 kits to use wilwood 4 piaton calipers the 3 kits use 12.0 rotors you can call me at 951 214-9555 you can email me at krecs1@hotmail.com 2 distributors selling my kits california datsun silver mine motors 1 Quote Link to comment
dscottdatsun Posted August 1, 2015 Report Share Posted August 1, 2015 Where do you find these K-E kits? Quote Link to comment
mklotz70 Posted August 1, 2015 Report Share Posted August 1, 2015 You might start by calling the phone number in the previous post.....or msg him. He's the guy making them. Quote Link to comment
krecs Posted August 17, 2015 Report Share Posted August 17, 2015 Where do you find these K-E kits? email me at krecs1@hotmail.com or text me at 951 214-9555 1 Quote Link to comment
twinchrissy Posted August 21, 2024 Report Share Posted August 21, 2024 Hi, I have a 79 620 Longbed and I will probably go down the drop spindles route. There seems to be about $100 difference in price between Beltech and Street Edge. Is there any difference? At the moment I'm on the original steel wheels and do understand that I'll probably need larger diameter wheels. Ive been looking at Nissan Navara/Pathfinder wheels which are 17" and 8" wide. Will these fit under stock wings or are the too fat? Any other suggestions of wheels for me to consider. Cheers from UK. Quote Link to comment
