onunez65falcon Posted January 5, 2014 Report Share Posted January 5, 2014 Where can I buy the bushing's that go under the cab? can I use a different year or model? Thank you. Quote Link to comment
wayno Posted January 5, 2014 Report Share Posted January 5, 2014 520 and 521 are the same, but it's not likely you will be able to find new, but one never knows. If you find any. be sure to tell the rest of us where and what the part number is. :) Quote Link to comment
kelowg Posted January 5, 2014 Report Share Posted January 5, 2014 Napa sells big rubber washers they motor mounts. Along with new nuts bolts and wahers, worked great on the 521. might b able to find something in poly but not the same size as far as i could find Quote Link to comment
Charlie69 Posted January 5, 2014 Report Share Posted January 5, 2014 Search my build thread I used all new bushings on my 520 there are quantities and Nissan part #. these were a combination of body bushings from other years and models, not exactly the same but do work nicely. Quote Link to comment
Charlie69 Posted January 5, 2014 Report Share Posted January 5, 2014 I will make it easy on you. Buy new bolts nuts and washers. 6 NISSAN 95156-14801 2 NISSAN 95153-B5000 4 NISSAN 95152-C8300 Quote Link to comment
