tr8er Posted December 21, 2013 Report Share Posted December 21, 2013 Can someone give the the bolt specs on the bolts that mate the flywheel to the crank. I need one this weekend, and left mine at home, so I've got nothing to compare to. Thanks. 1 Quote Link to comment
datzenmike Posted December 21, 2013 Report Share Posted December 21, 2013 100-120 ft lbs Quote Link to comment
tr8er Posted December 21, 2013 Author Report Share Posted December 21, 2013 thread, diameter, length? Oh and thanks. Quote Link to comment
datzenmike Posted December 21, 2013 Report Share Posted December 21, 2013 Sorry thought tightening. 12315-21000 about $2 each at dealer. 12315-A8600 is for the L16/18/L20B in the 620 truck so they should work also. These were also used under number 12315-U6000 through '80s Z24i Pathfinders, and trucks. So they should also work. If you get an L20B just check the laegth against one of the ones you do have to be sure it won't be too long and bottom out. Quote Link to comment
