daegodog Posted December 14, 2013 Report Share Posted December 14, 2013 We just finished replacing the clutch and got everything back in place and when you turn the key it wont turn over. I have traced everything back and it all is hooked up. Anyone have any ideas what to look at on this? I have an 81 720 4 speed. Quote Link to comment
wayno Posted December 14, 2013 Report Share Posted December 14, 2013 Can you jump the posts on the starter with a big screw driver and get it to turn? Quote Link to comment
datzenmike Posted December 14, 2013 Report Share Posted December 14, 2013 Does the ignition switch turn things like the wipers or heater fan on when turned to the ON position? NO...... Battery post(s) are loose or not making connection. Ground cable to intake is not making contact. Green fusible link is burned out or loose connections at positive battery terminal. YES.... see next below Is there a clicking sound when key turned to START?No..... remove and reconnect the Black/Red wire to the starter solenoid, it may be loose or just bad contact. YES... Solenoid is working. Remove and reconnect the positive cable to the starter lug. Possibly loose or bad connection. 1 Quote Link to comment
Boaty Posted December 14, 2013 Report Share Posted December 14, 2013 If it tries to crank but can't... could also be the input shaft bushing being bound up/super tight. I've had that happen before, even if you push the clutch in it still won't turn over.BUT if you put it in Neutral, it should fire just fine with the clutch in.Most likely not the case but something to think about. If it is, once you get going it only takes a few seconds of running for the bushing to wear-in and not keep a hold of the input shaft.For this reason I always clean the tip of the input shaft really well and give it a light skim coat of grease, and I take a dremel tool to the inside of the bushing with a felt bob and give it a quick buff. Also helps tremendously with installation too ;) Quote Link to comment
daegodog Posted December 14, 2013 Author Report Share Posted December 14, 2013 Is there a clicking sound when key turned to START? No..... remove and reconnect the Black/Red wire to the starter solenoid, it may be loose or just bad contact. YES... Solenoid is working. Remove and reconnect the positive cable to the starter lug. Possibly loose or bad connection. This was it. I checked it all then removed the starter and checked all the connections and it fired right up. Thank you all for the help. Quote Link to comment
EastBay521 Posted December 15, 2013 Report Share Posted December 15, 2013 I never woulda thought 720s came with 4speeds Quote Link to comment
datzenmike Posted December 15, 2013 Report Share Posted December 15, 2013 On the early 2wd ones the 4 speed was standard with the L20B and Z22 up to Oct '82. The 5 speed was optional though. All Heavy Duty or Cab Chassis options were only available with a 4 speed On all 4x4s the 4 speed was standard equipment except on the King Cab, on all L20B and Z22s through Oct '82 and for another 2 months with the new Z24 engine till mid model year in December '82. I can only assume that the 5 speed was optional. Quote Link to comment
