HardbodyNaps Posted December 14, 2013 Report Share Posted December 14, 2013 Is there a difference at all in the 5 speed transmissions from a 720 style pickup and a D21 pickup?! Both of them have the Z24 motors?!please help... 1 Quote Link to comment
ggzilla Posted December 14, 2013 Report Share Posted December 14, 2013 There are differences between two 720 both with Z24 engine. They came in three different lengths. Quote Link to comment
datzenmike Posted December 14, 2013 Report Share Posted December 14, 2013 Is there a difference at all in the 5 speed transmissions from a 720 style pickup and a D21 pickup?! Both of them have the Z24 motors?!please help... . Length is the big difference. Either will bolt up to the Z24 but will be longer or shorter. The 720 had 31.5" and 26" FS5W71B 5 speeds in Z series and SD diesel configuration. The 4x4 5 speeds did not have a speedometer drive in them as it was run from the transfer case. Used up until '86.5 After '86.5 the D21 Hardbody had the next gen FS5W71C 5 speeds AND F4W71C 4 SPEEDS !!! (so watch out, they look similar) in the 2wd that was about a inch shorter I believe, certainly NOT the same length as the 71B transmissions. The 4x4 had 5 speeds with a built in transfer case and cannot be used or mistaken for a 2wd transmission. Quote Link to comment
HardbodyNaps Posted December 14, 2013 Author Report Share Posted December 14, 2013 Are the bell housings different in the 720 and d21 z24 transmissions?! both of which are 2wd!! Quote Link to comment
datzenmike Posted December 14, 2013 Report Share Posted December 14, 2013 They should be the same if both are '84/'85 and newer. Earlier ones had a smaller counter bearing and 1st/2nd shift rod hole. Quote Link to comment
