Jester Posted August 28, 2015 Author Report Share Posted August 28, 2015 225-50-15 2 Quote Link to comment
]2eDeYe Posted August 28, 2015 Report Share Posted August 28, 2015 Love the blazer ralleys on there. 1 Quote Link to comment
Jester Posted August 31, 2015 Author Report Share Posted August 31, 2015 I really like the 8" wide on the back. Just not a big fan on the front. I found a 7" wide rally that is the same backspace. I am going to try and find one more and swap out the front two. Maybe even drop down to a 195 on the fronts as well. We'll see. This truck MAY get tore apart this winter for the VG. :rolleyes: :rolleyes: 1 Quote Link to comment
Jester Posted August 31, 2015 Author Report Share Posted August 31, 2015 I ended up having to roll the rears out for the Shasta trip. Just too close. 2 Quote Link to comment
sebpv Posted August 31, 2015 Report Share Posted August 31, 2015 Do you know what offset they are? I have 8in +2. I havent fitted them but I read its not an issue with my offset... I know bla bla...fit the rims to the truck not the oppositel ;) Quote Link to comment
Jester Posted September 1, 2015 Author Report Share Posted September 1, 2015 Here is a basic offset chart.I'll have to measure them again when I pull them to roll my front fenders. I want to say 3 3/4" Quote Link to comment
sebpv Posted September 1, 2015 Report Share Posted September 1, 2015 so my wheels should in theory stick out less by 3/4 on an inch. So no pulling required. But That could change since I put 4in blocks in the back... And did you actually measure 3in drop after you de-arched the leaves? Quote Link to comment
Jester Posted September 1, 2015 Author Report Share Posted September 1, 2015 OK, I went out and my measured my extra wheel. Laying a 2' level across the wheel and measuring to the mounting surface is 4". It is 3-3/4" from the inner lip. Quote Link to comment
sebpv Posted September 1, 2015 Report Share Posted September 1, 2015 that translates into a -19 offset according to the sheet. I should check mine since they're not mounted yet. And thx for the info! Quote Link to comment
Jester Posted January 13, 2016 Author Report Share Posted January 13, 2016 I haven't done much other than drive this thing every damn day. I love this truck. I was forced to put a new starter on a couple weeks ago. I also put in some new NGK wires, Standard Ign. cap and rotor and a fresh set of NGK BP6ES. No resistor plugs! I ran these plugs for about 1000 miles and pulled them just to see how they looked. Color is a little whiter than I would like to see and no signs of heat range rings. So, tonight I put in another set of plugs, BP5ES this time. Main throttle shaft has some play so I am having a difficult time getting the carb to be concistant. I need to order some jets and do some playing. That or just say fuck it and drive it the way it is and concentrate on getting more important stuff done. I also picked up an old Vandercook printing table base that I turned into a fab table. Dug my front frame section out of the back yard and and cut the motor mounts off. Trying to concentrate on suspension before I worry about the VG. I WILL NOT have torsion bars on this truck with a VG. After helping Yello620 on his, I want them gone. The plan is to raise the upper and lower arms 2" (this should get me to a 4" ride hight) and extend them both 1 3/8" to keep my wheels roughly where they are now. I plan to switch to either a 17 or 18" wheel with about a +32mm offset. I wanted 16's but they just don't seem to be making many16's anymore. Only having half a frame is proving difficult to get accurate measurements and determining a "level" starting point. Wishing now that I would have kept it in one peice and just assembled my running gear then swapped my body on. 1 Quote Link to comment
Lockleaf Posted January 13, 2016 Report Share Posted January 13, 2016 Not sure, but I think you are running a Weber carb? If so, there are bearings that can be installed on the main throttle shaft. They will eliminate vacuum leaks at the shaft and fix the wobble. Pegasus racing sells a set of them. Quote Link to comment
Jester Posted January 13, 2016 Author Report Share Posted January 13, 2016 Thank you. Quote Link to comment
Lockleaf Posted January 13, 2016 Report Share Posted January 13, 2016 Https://youtu.be/abi40OrA8uY Install vid https://www.pegasusautoracing.com/productdetails.asp?RecID=5949 This is the set I bought and installed on my Weber 32/36 1 Quote Link to comment
Jester Posted January 13, 2016 Author Report Share Posted January 13, 2016 I wondered how the hell you could possibly install these without enlarginig the holes. Now I see. Thanks for the links. Quote Link to comment
S30Jay Posted January 16, 2016 Report Share Posted January 16, 2016 Great looking truck! I like the rallyes....I think the 8" s work up front too. I'm sure the 7s will too. How's it ride like that? I'll bet it handles pretty good. Quote Link to comment
Jester Posted January 16, 2016 Author Report Share Posted January 16, 2016 It handles OK. The frontend needs rebuild BAD! Rather than rebuild the factory suspension I am in the process of figuring out how to build a true A arm setup on the top and bottom. I want to eliminate the TC rods, drop 2 inches of ride higth and lengthen the arms. I want to keep the wheel/tire where they are currently at but get the scub radius back where it needs to be. Here's my new table. A little small, but, appropriate for the siz of my garage. :D 4 Quote Link to comment
S30Jay Posted January 16, 2016 Report Share Posted January 16, 2016 Decent looking table, It'll do the job. Are you planning on running coil springs or coilovers...or keeping the torsion bars. Years ago I had a 1992 Toyota 2wd pickup and if I remember right it had upper and lower c.arms. It held up well too, wonder if you could adapt something like that? Of course that had t. Bars I believe as well 1 Quote Link to comment
]2eDeYe Posted January 16, 2016 Report Share Posted January 16, 2016 I have some ideas for a rack and pinion, need to do some diggingTo directly replace the centerlink would need a rack approx 20" overall length with about 4" of travel. 1 Quote Link to comment
Jester Posted January 17, 2016 Author Report Share Posted January 17, 2016 Decent looking table, It'll do the job. Are you planning on running coil springs or coilovers...or keeping the torsion bars. Years ago I had a 1992 Toyota 2wd pickup and if I remember right it had upper and lower c.arms. It held up well too, wonder if you could adapt something like that? Of course that had t. Bars I believe as well I will be using coilovers. Looking for some that are MAX 4" travel. From ride hight it will have 1-1 1/2" of availavle down travel and 2" upward. And I'm not looking to run the Toyota arms, just the spindles. I have some ideas for a rack and pinion, need to do some digging To directly replace the centerlink would need a rack approx 20" overall length with about 4" of travel. Lower control arm pivots will be @ 16 1/4" if I leave them in their stock side to side location. IF I move them outward, which I could, they will be 18 1/2". I need the ball joints in the rack to be wherever my pivots are. Tryig to keep as much bump steer out as possible. Does your idea HAVE to be 20"? What are you thinking? I appreciate the feedback guys. It's nice to bounce ideas off you guys and hear your thoughts. Quote Link to comment
Jester Posted January 17, 2016 Author Report Share Posted January 17, 2016 Oh ya, went to look at a '81 KC 720 4x4 today. Belongs to my uncle :wub: and he is GIVING it to me. :frantics: I may have a new daily while I officially build my 620! She is ruff and muddy, thanks cuz, and a little beat up. BUT, no rust. And it needs a new engine. Divorced T-case.......soooooo how about a L20B/4spd 4x4? :rolleyes: 2 Quote Link to comment
Rhino13 Posted January 17, 2016 Report Share Posted January 17, 2016 Pics!! I'll have to come up and see it! 1 Quote Link to comment
Jester Posted January 17, 2016 Author Report Share Posted January 17, 2016 Putting some pics up on Photobucket right now. I'll post them in a few. 2 Quote Link to comment
Jester Posted January 17, 2016 Author Report Share Posted January 17, 2016 Low mileage, 3 previous owners all of which I know personally. Including the guy who bought it brand new. Needs a fender and bath for starters. 3 Quote Link to comment
Lockleaf Posted January 17, 2016 Report Share Posted January 17, 2016 Sweet. 720s are my favorites. I currently have 3 (well 2.5) here at my house. 1 Quote Link to comment
Jester Posted January 17, 2016 Author Report Share Posted January 17, 2016 I may start some kind of build thread, of sort, when I get it home. I told my uncle I would pick up a new R F axle, fix it, and drive it home. Probably hit the car wash in Newberg on my way home. Maybe stop @ Yello620's on the way home to show off my new truck. :fu: I'd say we could go wheel it before I go wash it but I don't know how long the Z22 is going to hold on. He seys it smokes like a banshee. Got an extra Z engine? Spent some time in the garage tonight thinking and playing with measuring devises. Started off leveling the table. Then I used my square to find the center of the holes. Once I had both sides I could properly determine the center and start tranfering it up. I took this picture for reference. I'm putting it hear more for me than you. It measured out to 4 1/8" with blade flat on table. In the end the pivot will be two inches up. I haven't made a final decision on pivot width center to center yet. Still looking at racks. Came out to 2 15/16" 3 Quote Link to comment
