GORILLARILLA21` Posted November 20, 2013 Report Share Posted November 20, 2013 I have a drive line i took out of my datsun that was cut to fit the 280zx na manual tranny. I'm in the process of doing a sr20 swap and I think I read somewhere that the sr20 transmission is a bit longer? I can't find it again, but was wondering if anyone has the measurement of the 280 transmission? Help is appreciated. Thanks in advance! 1 Quote Link to comment
Stupid_fast Posted November 20, 2013 Report Share Posted November 20, 2013 5 speed by 2" I believe. C series box same as KA. Shifter assembly is bulkier too. Google is your friend. If you're doing an SR20 swap, I'd hope you had the capability to mock it up yourself. Quote Link to comment
GORILLARILLA21` Posted November 20, 2013 Author Report Share Posted November 20, 2013 I will am just waiting to go pick up the tranny crossmember as I dunno where I placed the old one :sleep: Quote Link to comment
jrock4224 Posted December 12, 2013 Report Share Posted December 12, 2013 I have both these trannys at my shop should u wanna see in person and measure Quote Link to comment
jrock4224 Posted December 12, 2013 Report Share Posted December 12, 2013 oh and is this why u haven't needed your ka valve cover ? cuz sr.........I see how u are ...lol Quote Link to comment
datzenmike Posted December 12, 2013 Report Share Posted December 12, 2013 The '77-'78 280x 4 and 5 speeds were 31.5" long. This is measured by standing the transmission up on end on two 2x4s, placing a straight edge across the output (remove any metal dust shield if there is one) and measuring VERTICALLY and parallel to the center line of the transmission, up from the bell housing surface that mates against the engine block, to the straight edge. This gives the absolute length and avoids a longer and incorrect slope distance that you would get from the transmission end to the bell. IF your driveshaft fits perfectly it should be 37 3/8" or 37.375" U joint to U joint I believe. This is the traditional length used for the z or zx 71B 5 speed swap. Measure the SR 5 speed using the method above and subtract 31.5" and this is how much shorter the driveshaft must be. I confident the SR's 71C transmission will be something like 34 or 35" long but definitely longer than the 71B Quote Link to comment
I'm BLUE Posted December 12, 2013 Report Share Posted December 12, 2013 "71B" 280zx 5spd's = 31.5" inches long "71C" SR20det/KA24e/de 5spd = 33.5" inches long (just barely but very safe to say so) Like Stupid_fast said the shifter/shifter mounting area.. is bulkier to. You can get cheap short throw shifters just about anywhere for these or second hand if you watch. Good Luck and have fun. 1 Quote Link to comment
