Xnke Posted August 21, 2008 Report Share Posted August 21, 2008 Hi, my name is Jake, and I build L motors. (yes, it is an addiction...) Anyway, for those of you who buy new rocker arms every time you change cams, you know it isn't cheap. 13$ per rocker, 8 or 12 rockers per engine, that's 104$ or 156$ per cam, plus the cam! SO DON'T PAY IT! *Factory Nissan* rockers can be refinished 3-5 times before they are worn out. I can and will refinish your *Factory Nissan* rocker arms for $2.50 per rocker, plus your shipping costs. For a four cylinder engine, that's 20$ per engine, plus maybe 20$ shipping. For a six, that's 30$ plus 20$ shipping. MUCH more reasonable. Now, you notice I stress that these must be FACTORY NISSAN rockers, why? Because aftermarket rockers have the wear pad made of a softer material, and they don't resurface well. So, anyone who wants me to refinish your rocker arms, send me a PM here and I will get with you on exact pricing (shipping) and whether or not your rockers can be refinished. I can't fix rockers that have any pitting or chunks missing,but normal wear can be easily taken care of. Link to comment
Jason Posted August 21, 2008 Report Share Posted August 21, 2008 How do you tell if you have the factory Nissan rockers? I'm in for this if I do have them! Thanks Link to comment
hang_510 Posted August 21, 2008 Report Share Posted August 21, 2008 normal wear = cam divots? i have 2 sets id like done. im gonna pass if the shipping is ridiculous...$20 :eek: Link to comment
banzai510(hainz) Posted August 21, 2008 Report Share Posted August 21, 2008 You have a process on HOW you do them and photos of you doing them. upclose photo of the finnished product. I might just send you my old rockers so you can just keep them Link to comment
Mark_Z28 Posted August 22, 2008 Report Share Posted August 22, 2008 Doesnt refinishing the pads make the geometry of the arms off and then have to buy lash pads? Link to comment
]2eDeYe Posted August 22, 2008 Report Share Posted August 22, 2008 It would only affect the amount of adjustment. Probably not even enough that you would notice. Link to comment
Xnke Posted August 26, 2008 Author Report Share Posted August 26, 2008 The 20$ shipping is a highball estimate, meant to cover somebody shipping them in from Antarctica or somewhere equally strange. I only charge the actual shipping cost. Yes, normal wear includes cam divots, but if you have doubts, send me a picture and I'll let you know. USUALLY, you won't have a problem. As far as knowing if they are factory rockers, USUALLY, they will have the Nissan symbol on the side of the rocker somewhere, but if you have never replaced the cam or rockers, I'll take it on faith that you have Nissan rockers. Like I said, the aftermarket rockers are a different hardness and don't resurface well. As far as photos go, I can take some. Process, it's easy! Only catch is you need a surface plate to check the rockers on. 1. Buy a good surface plate. (Enco Tool company has excellent deals.) 2. Get a load of 120 grit silicon carbide (black/wet or dry) sandpaper 3. place the paper on the plate, grit side up, and dampen enough that the water holds the paper in place. Practice. 4. Clean rockers carefully, and evaluate if it's worth refinishing them. 5. Drag rocker across the wetted paper, being certain to apply even pressure left to right, and turn your wrist as you work the rocker to evenly grind the high spots down. Again, practice. Any flat spots on the rocker radius will eat camshafts. Work from end to end, not side to side. 6. CLEAN EVERYTHING. I mean it. be obsessive. 7. Using some machinist's bearing blue, check the rocker arm against the surface plate, looking for flat spots, low spots, and pitting or irregularity. A trained eye and practice using bearing blue is a huge help. 8. Clean and oil your resurfaced rockers to prevent rust. Or, you can send them to Delta Camshaft for resurfacing for 4$ per rocker. I don't know the process they use, but it is probably a mechanized version of the above. Link to comment
