Richb Posted November 19, 2013 Report Share Posted November 19, 2013 I am currently trying to revive a '79 FS5W60L and will be needing one, possibly two internal parts for it. I will post a wanted post to the classifieds but wanted to ask here about possible parts interchange with the FS5W63A. The part in question is the first and reverse synchronizer hub. Mine has a chip out of it along the edge of one of the shift insert slots. Since the two transmissions are based on the same design and the hubs look similar I was thinking Nisan may have used the same part in both transmissions. Talking with the dealer parts man both hubs have similar parts numbers with only the last part being different. The 60L’s part number ends in -H7300 while the 63A’s part number ends in -N9300. Anyone have any experience or knowledge with this kind of thing. The other part I may need is the main shaft but that I know is different between the two transmissions. It has a messed up snap ring groove on the forward end. I'm going to talk to a machinist to see if it can be cut deeper and a new snap ring sourced. So I may be on the lookout for that also. Thanks for any info. Rich 1 Quote Link to comment
Dime Dave Posted November 19, 2013 Report Share Posted November 19, 2013 Rich, Not going to work. Basically everything in a 63 series is 63 series. The dogleg 5 speed does share parts with the 510 4 speed (synchros, coupling rings, forks), but that is about it. Quote Link to comment
datzenmike Posted November 19, 2013 Report Share Posted November 19, 2013 Well my Nissan parts look up says they are the same number. FS5W60L...... 32258-H9001 1st/rev synchronizer hub ($130) FS5W63A...... 32258-H9001 1st/rev synchronizer hub ($125) .... Why they are two different prices baffles me. I remember a friend changing a U joint in an early Cadillac. The exact same one ( GM part number) for an Olds was half price. The only part number with a ?????- H7300 suffix was... 32272-H7300 a needle bearing used in both transmissions There were no ?????-N9300 suffix numbers at all in the FS5W63A or the FS5W60L transmission gear sections. So I don't know what he was looking up at all. Quote Link to comment
EricJB Posted November 20, 2013 Report Share Posted November 20, 2013 I ripped all the teeth off of 1st gear on a 63 dogleg. I still have it, minus the front case. If you know what you need, bring your stuff up and match it up. Quote Link to comment
Richb Posted December 6, 2013 Author Report Share Posted December 6, 2013 Thanks for the quick responses and sorry for my late reply. Take a crisis and add a holiday and you lose two weeks time really fast. I also need to apologize for my first post here having a couple of errors. Not only am I trying to revive my FS5W60L, but I am also helping a friend rebuild his FS5W60A that seized the input shaft bearing. So too many part numbers floating around my in my head. The part numbers given to me by the parts man were the same as datzen mike posted with the exception of the letter in the second set which was H for the 60L and N for the 63A. But when he printed the numbers out for me it just listed the one number with the H. This bring s us to my second error which is that while I was sure I needed the 1st/rev synchronizer hub it turns out that I need the 2nd/3rd synchronizer hub. so the same question applies, are these hubs shared between the 60L and the 63A transmissions. Mike, sorry for wasting your time with the wrong info. Eric if you think you have the 2nd/3rd Synchronizer hub I will PM you to set something up. To follow up on having the main shaft machined. The one shop I talked to said that since the shaft was most likely hardened is could cost up to $500 to have the work done. So I will just keep looking. Thanks Rich Quote Link to comment
EricJB Posted December 6, 2013 Report Share Posted December 6, 2013 There was a holiday? I was so sick, I slept from 8pm weds. to noon on Friday. I didn't eat for a week. No worries here. Yes, I have pretty much all of it. It is still together on the mainshaft. Quote Link to comment
ggzilla Posted December 6, 2013 Report Share Posted December 6, 2013 Both of those are dogleg 5-speeds but no interchange of parts except for some synchros. The 63 is bigger and heavier than need be for an A14 or A15 engine. Quote Link to comment
ggzilla Posted December 6, 2013 Report Share Posted December 6, 2013 2nd/3rd synchronizer hub for 60L dogleg is 32601-H9001. Differs from the 1st/Rev hub number previously discussed. Quote Link to comment
ggzilla Posted December 8, 2013 Report Share Posted December 8, 2013 32601-N9000 HUB-SYNCHRONIZER 2ND & 3RD FS5W63A $81 at Nissan Quote Link to comment
