kks_john Posted August 20, 2008 Report Share Posted August 20, 2008 I am in need of a crush sleeve for a 66 411 and have had zero luck in tracking one down. not one driveline shop in town has been able to help and no online source has them for anything that the pinion seal fits... my question is; are we just F'd when we need to replace the pinion seal in our 411s? Quote Link to comment
ppeters914 Posted August 21, 2008 Report Share Posted August 21, 2008 What part are we talking about here? :confused: Quote Link to comment
homewrecker Posted August 21, 2008 Report Share Posted August 21, 2008 some times you can get away with reusing it just check the drag befor and after if its the same it should be fine. Quote Link to comment
ppeters914 Posted August 21, 2008 Report Share Posted August 21, 2008 School me. What part we talking about here? Quote Link to comment
ggzilla Posted August 21, 2008 Report Share Posted August 21, 2008 Nissan dealer can get the differential crush part. Quote Link to comment
kks_john Posted August 21, 2008 Author Report Share Posted August 21, 2008 local dealer said no can do. I will try courtesy nissan any other dealers good for datsuns? Quote Link to comment
ggzilla Posted August 21, 2008 Report Share Posted August 21, 2008 You will need the part number. Which part exactly are you looking for? I probably can find the PN. Quote Link to comment
ppeters914 Posted August 22, 2008 Report Share Posted August 22, 2008 You will need the part number. Which part exactly are you looking for? I probably can find the PN. D-uh. Anyone notice the pic from the 411 PARTS MANUAL I posted above? Tell me which part and I can post the part number. Quote Link to comment
ggzilla Posted August 22, 2008 Report Share Posted August 22, 2008 Yes, I have the same parts manual. None of the parts are called "crush" though. Quote Link to comment
kks_john Posted August 22, 2008 Author Report Share Posted August 22, 2008 I think it is 20. not sure though. what is #20 called? Quote Link to comment
ppeters914 Posted August 22, 2008 Report Share Posted August 22, 2008 Yes, I have the same parts manual. None of the parts are called "crush" though. Yeah, that's why I was asking earlier. :D I think it is 20. not sure though. what is #20 called? Quote Link to comment
kks_john Posted August 23, 2008 Author Report Share Posted August 23, 2008 GENIUS! I assume the "as required for 1.3" means it cannot be reused to many times...and that there are THREE part numbers...strange... that would be it (could this be before the nissan's figured out about crush sleeves?!) I think. I will see if the dealer can get all three and I'll see what works. yay. thank you so much. do you have the manual on pdf or paper? how much can I buy a copy from you if it's pdf? Quote Link to comment
yello620 Posted August 23, 2008 Report Share Posted August 23, 2008 What is number 27 called in that picture. Wondering if those are shims that set the preload, and that this might be before the days of the crush sleeve. Jason Quote Link to comment
kks_john Posted August 23, 2008 Author Report Share Posted August 23, 2008 could be. what is the number for 27? Quote Link to comment
ppeters914 Posted August 24, 2008 Report Share Posted August 24, 2008 What is number 27 called in that picture. Wondering if those are shims that set the preload, and that this might be before the days of the crush sleeve. could be. what is the number for 27? They're listed as WASHER-adjusting, drive pinion bearing for the 1.3L (15 part numbers), and SHIM-adjusting, drive pinion (5 part numbers) and WASHER-thrust, drive pinion bearing (8 part numbers) for the 1.6L. The different part numbers are for different thicknesses I believe. The 1.3L part descriptions says 2.35T, 2.33T, 2.31T, etc. The 1.6L shims say 0.050, 0.075, 0.125, etc.. The 1.6L washers have no extra info. Quote Link to comment
kks_john Posted August 25, 2008 Author Report Share Posted August 25, 2008 that's it then, no crush sleeve, only shims. hmm. thank you for checking that out for me. Quote Link to comment
